Hi all,
According to Khronos specs, it must be possible to specify as compiler option an include directory.
As far as I can see, the option does not interpret pathnames with spaces correctly, even if the pathname is enclosed in double quotes. When I replace the pathname (see below) by “C:\TEST”, no clang-error is reported.
Can you see if I do something wrong?
Thanks,
Jan
-I “c:\Users\Jan\Documents\Visual Studio 2008\Projects\triangularnbody\nbody-ring-test-opencl”
clang: Too many positional arguments specified!
Can specify at most 1 positional arguments: See: clang --help
Edit:
I solved the problem for now by resorting to a windows-function (GetShortPathName()), introducing a platform-dependency:
_getcwd(buffer,sizeof(buffer));
int lenghth=GetShortPathName(buffer,buf2,sizeof(buf2));
sprintf(buffer,"%s -I %s",OPENCL_OPTIONS,buf2);
int cl_build_err=clBuildProgram(clprog, 0, NULL, buffer, NULL, NULL);
I tried the same code in my ocl programm. It works but what if I want to specify a subdir of cwd as my include dir for example src/header. I tried the following:
sprintf(buffer,"%s -I %s\\include",OPENCL_OPTIONS,buf2); // puts in an additional include subdir
This is after the GetShortPathName() call.
Then copied the header file into the include dir and renamed it to make sure that a positive result would be valid.
This worked.
So, maybe your buffers are a bit small, or the GetShortPathName() does something funny. You could check this in debug mode.
Since I’m not using ocl stuff, I allocate a buffer also for clGetProgramBuildInfo(); if you see logs of strange characters, maybe that buffer (alloced by the ocl library?) could be too small.
