When attempting to update a Xavier system from JP4.4.1 to JP5.1 we encountered an error in stage 2 of flashing (installing of system packages). Specifically, nvidia-l4t-jetson-multimedia-api
could not be installed:
4:37:48.358 - info: Event: NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - error is: command terminated with error
14:37:48.374 - warn: Found known error: nvidia-l4t-jetson-multimedia-api : Depends: nvidia-l4t-camera (= 35.2.1-20230121191456) but 35.2.1-20230124153320 is to be installed
Depends: nvidia-l4t-multimedia (= 35.2.1-20230121191456) but 35.2.1-20230124153320 is to be installed
Depends: nvidia-l4t-multimedia-utils (= 35.2.1-20230121191456) but 35.2.1-20230124153320 is to be installed
E: Unable to correct problems, you have held broken packages.
We were able to upgrade this system to JP5.0.2 without issue, and then attempted to update to JP5.1 and encountered the same issue.
Logs for each flash are attached:
sdkm-2023-01-25-15-03-49.log (2.3 MB) JP4.4.1 → JP5.1
sdkm-2023-01-26-13-51-14.log (453.5 KB) JP4.4.1 → JP5.0.2
sdkm-2023-01-26-14-01-52.log (1.3 MB) JP5.0.2 → JP5.1
I have the additional logs from sdkm but am unsure which to provide here…
