Cannot upgrade OTA from R35.4.1. to R35.5.0
Hi Team, I’m trying to update orin nano devkit 8gb OTA from R35.4.1 to R35.5.0 with ROOTFS_AB enable. After pack payload and run sudo ./nv_ota_start.sh /ota/ota_payload_package.tar.gz I got the issue below. Do you know why?
decompress_ota_package: end at Mon 06 May 2024 10:59:04 AM UTC
nv_ota_update_without_layout_change.sh
Command: nv_ota_update_without_layout_change.sh
check_target_board /ota_work TARGET_BOARD
get_chip_id CHIP_ID
ota_choose_images /ota_work
COMPATIBLE_SPEC=3767–0003–1–jetson-orin-nano-devkit-
TEGRA_CHIPID=0x23
_BOARD_SPEC_NAME=3767–0003-
Copy files from ./images-R35-ToT/3767–0003-/ to ./images-R35-ToT/
is_rootfs_a_b_enabled ROOTFS_AB_ENABLED ROOTFS_CURRENT_SLOT
ROOTFS_AB_ENABLED=1
ROOTFS_CURRENT_SLOT=0
is_rootfs_encryption_enabled ROOTFS_ENC_ENABLED
ROOTFS_ENC_ENABLED=0
get_update_slot UPDATE_SLOT
UPDATE_SLOT=B
get_update_control /ota_work UPDATE_BOOTLOADER UPDATE_ROOTFS
UPDATE_BOOTLOADER=0, UPDATE_ROOTFS=1
select_uefi_capsule /ota_work
check_bsp_version /ota_work BASE_VERSION
The version of OTA package(R35-5) does not match the version of current system(R35-4), please check whether the OTA package is correct
Failed to run “check_bsp_version /ota_work BASE_VERSION”
here is command I create OTA package sudo ROOTFS_AB=1 -E ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh -r --external-device nvme0n1 -S 20GiB jetson-orin-nano-devkit R35-5
Sorry, I made a mistake of bsp_version. will try with R35-4
