• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.0
• TensorRT Version Container
• NVIDIA GPU Driver Version (valid for GPU only) 565
• Issue Type( questions, new requirements, bugs) Question & Bug
Can not use protobuf provided inside container, in DS-7.0, the author added /root/.local/lib
into LD_LIBRARY_PATH
, which contains grpc, protobuf, absl (all dynamic). But they are incompatible with Deepstream itself when using nvinferserver
From the call stack, seems this issue was caused by libnvdsgst_inferserver.so
, the call stack:
I think the inferserver try dlload tritonserver when startup, and tritonserver contains a static protobuf, while my program already load a dynamic version, then cause this issue ??
maybe using the protobuf from /opt/tritonclient/lib
will fix, but it’s sub-optimal, because i need to manage all dependencies by hand without cmake, not to mention I may use grpc in future, which would be more complex.
So is there any better way to deal with this?
Code to reproduce:
test.cc
int main(int argc, char *argv[]) {
gst_init(&argc, &argv);
assert(gst_is_initialized());
test::Test t;
t.set_name("hello");
std::cout << grpc::Version() << " " << t.ShortDebugString() << std::endl;
std::cout << t.ShortDebugString() << std::endl;
auto *urisrc = gst_element_factory_make("nvurisrcbin", NULL);
auto *inferserver = gst_element_factory_make("nvinferserver", NULL);
return 0;
test.proto
syntax = "proto3";
package test;
message Test {
string name = 1;
cmake
cmake_minimum_required(VERSION 3.17.0)
project(
nvds_test
VERSION 0.1
LANGUAGES C CXX)
list(APPEND CMAKE_MODULE_PATH "/root/.local/lib/cmake")
find_package(PkgConfig REQUIRED)
find_package(Protobuf REQUIRED)
find_package(gRPC REQUIRED)
pkg_check_modules(glib2 REQUIRED glib-2.0>=2.0 IMPORTED_TARGET)
pkg_check_modules(
gstreamer
REQUIRED
gstreamer-1.0
gstreamer-audio-1.0
gstreamer-video-1.0
gstreamer-base-1.0
IMPORTED_TARGET)
add_library(proto STATIC test.proto)
protobuf_generate(
TARGET
proto
LANGUAGE
cpp
PLUGIN
$<TARGET_FILE:protobuf::protoc>)
target_link_libraries(proto PRIVATE ${_GRPC} protobuf::libprotobuf)
target_include_directories(
proto PUBLIC $<BUILD_INTERFACE:${CMAKE_CURRENT_BINARY_DIR}>)
if(TARGET gRPC::grpc++)
set(_GRPC gRPC::grpc++)
message(DEBUG "gRPC::grpc++")
elseif(TARGET grpc++)
set(_GRPC grpc++)
message(DEBUG "grpc++")
else()
message(FATAL_ERROR "grpc++ not found")
endif()
add_executable(${PROJECT_NAME} test.cc)
${PROJECT_NAME} PRIVATE ${CMAKE_CURRENT_SOURCE_DIR}
target_link_libraries(${PROJECT_NAME} PRIVATE PkgConfig::glib2 PkgConfig::gstreamer protobuf::libprotobuf ${_GRPC} proto )
