Cannot Use Custom Animations with People Simulation Extension
Following the steps on the Omniverse People Simulation Extension Documentation page, I successfully managed to control a character downloaded from ArtCore using the People Simulation Extension. My next goal is to control the motions downloaded from ArtCore through the same People Simulation interface.
During this process, I found the “Add a Custom Command” section in the documentation, which describes adding custom commands. However, while testing this, I couldn’t see the required parameters in my animation as described in the following step:
Open an animation USD, add all the attributes listed above and to the root prim. In this example, “CustomCommandName” is set to “CallingStand” and “CustomCommandTemplate” is set to “Timing”.
While following these steps, I am unable to see these parameters in my animation. Can you assist me with this issue?
