Hi all,
I am using GTX960 with CUDA 7.5 in Visual Studio 2013. After I have changed to compute_52,sm_52(in CUDA C/C++ -> Device -> Code Generation),
I still failed to use dynamic parallel. Anything else should I configure? Thanks in advance!
Following is the compiling information:
1>D:/RLF/RLF/RLF/kernel.cu(250): error : calling a global function(“change_neighbor_state”) from a global function(“color_max_degree_flow”) is only allowed on the compute_35 architecture or above
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 7.5.targets(604,9): error MSB3721: The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.5\bin\nvcc.exe” -gencode=arch=compute_52,code=“sm_52,compute_52” -gencode=arch=compute_20,code=“sm_20,compute_20” --use-local-env --cl-version 2013 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin” -rdc=true -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.5\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.5\include" -G --keep-dir Debug -maxrregcount=0 --machine 32 --compile -cudart static -g -DWIN32 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Zi /RTC1 /MDd " -o Debug\kernel.cu.obj “D:\RLF\RLF\RLF\kernel.cu”” exited with code 2.
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Best,
