cannot use I2S1 and I2S3 at our application purpose, but I2S2 works.
In our customized target board, three I2S ports of Xavier module are all in slave mode and send/receive TDM16 data to/from other front-end dsp device.
That is, the dsp as I2S master generates BCLK and LRCK for all I2S ports.
Changing I2S port of Xavier from default master mode to slave was done by asking forum here and being guided.
(https://devtalk.nvidia.com/default/topic/1063987/i-cannot-set-i2s-slave-mode-at-jetpack-4-x-both-tx2-and-xavier-/?offset=7#5388564)
As a workaround guided (I think it is more perfect) I flashed kernel image including modified dts and then inserted sdk components (CUDA,etc) by using sdk manager.
However, going further, I have faced a new problem.
At I2S1 and I2S3(this is module port name, it actually corresponds to I2S4 internal setting) channel, ALSA snd_pcm_readi doesn’t work and returns “Input/output error”.
At I2S2 channel, snd_pcm_readi/writei seem to work well without error. (have not been fully checked yet)
Because we did the similar work successfully for four I2S ports at TX2 based target board (JetPack3.2.1 L4T 28.2.1) last year and we are validating re-using the same application (of course modified properly to Xavier platform), I expect carefully I did not make any mistake on going over this issue.
Seeing audio related dts file, I found the codes which look related with I2S1, I2S4 as follows.
tegra194-audio-p2822-0000.dtsi
i2c@c250000 {
rt5658: rt5659.7-001a@1a {
compatible = “realtek,rt5658”;
reg = <0x1a>;
		realtek,jd-src = <RT5659_JD_NULL>;
		realtek,dmic1-data-pin = <RT5659_DMIC1_NULL>;
		realtek,dmic2-data-pin = <RT5659_DMIC2_DATA_IN2P>;
		gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(S, 5) 0>;
		//status = "okay"; //org
		status = "disabled"; //weacom
/* Default for all I2S is long fsync width(31) */
#if 0 //weacom
aconnect@2a41000 {
ahub {
/* I2S4 in Short frame sync for BT SCO */
i2s@2901300 {
fsync-width = <0>;
#endif
/* org
nvidia,dai-link-1 {
link-name = “rt565x-playback”;
codec-dai = <&rt5658>;
codec-dai-name = “rt5659-aif1”;
Override with BT SCO entries /
org
nvidia,dai-link-4 {
format = “dsp_a”;
tx-mask = <0xFF>;
rx-mask = <0xFF>;
bitclock-inversion;
bclk_ratio = <4>;
srate = <8000>;
num-channel = <1>;
By any chance, does it have something to do with this issue?
Of course I tried to disable these codes as above, but is there any other point which I have to touch?
If my information is not enough please let me know.
Regards,
Lunalovre
Hello!
I can confirm that we do test all I2S interfaces supported by Xavier and so this should work. Can you try the following …
$ alsactl init tegrasndt19xmob
$ amixer -c tegrasndt19xmob sset "ADMAIF3 Mux" I2S4
$ amixer -c tegrasndt19xmob sset "I2S4 Mux" ADMAIF3
$ amixer -c tegrasndt19xmob sset "I2S4 codec frame mode" dsp-a
$ arecord -D hw:tegrasndt19xmob,2 -c 16 -f S16_LE -r 48000 -d 10 cap.wav
Regards,
Jon
I have another question.
I have observed by oscilloscope the phase relation of signal BCLK vs data of the working I2S2 output channel.
The result shows “bitclock-inversion” setting has no effect. (at dts setting as shown below)
If it had effect, data must change at rising edge of clock, but it doesn’t.
nvidia,dai-link-2 {
link-name = “spdif-dit-1”;
cpu-dai = <&tegra_i2s2>;
codec-dai = <&spdif_dit1>;
cpu-dai-name = “I2S2”;
codec-dai-name = “dit-hifi”;
format = “dsp_a”; /org: “i2s”;/
bitclock-master; /org: none/
frame-master; /org: none/
bitclock-inversion; /org: none/
frame-noninversion; /org: none/
bit-format = “s32_le”; /org: “s16_le”;/
bclk_ratio = <1>;
srate = <48000>;
num-channel = <16>; /org: <2>;/
tx-mask=<0xFFFF>; /org: none/
rx-mask=<0xFFFF>; /org: none/
ignore_suspend;
name-prefix = “y”;
status = “okay”;
Who knows about this?
Hello!
It definitely, should the I2S driver programs the polarity of the bit clock based upon this setting. Can you dump the I2S registers for the different configuration …
$ sudo cat /sys/kernel/debug/regmap/tegra210-i2s.1/registers
Regards,
Jon
Hello Jon,
Sorry, I found your reply for my first question late.
Let me call my two issues, issue#1 and issue#2 in order.
Issue#1: I2S1 and I2S4(I’ll call as internal name instead of module pin name) don’t work.
Issue#2: The working I2S2 channel seems to have no effect of bitclock-inversion setting in dts.
Firstly regarding Issue#1,
my answer after experiment is as follows:
(My experiment was done in our target board. It has no codec ic as devkit and has dsp device.)
amixer settings
amixer -c tegrasndt19xmob cset name=“I2S1 Channels” “16”
amixer -c tegrasndt19xmob cset name=“ADMAIF1 Mux” “I2S1”
amixer -c tegrasndt19xmob cset name=“I2S1 Mux” “ADMAIF1”
amixer -c tegrasndt19xmob cset name=“I2S2 Channels” “16”
amixer -c tegrasndt19xmob cset name=“ADMAIF2 Mux” “I2S2”
amixer -c tegrasndt19xmob cset name=“I2S2 Mux” “ADMAIF2”
amixer -c tegrasndt19xmob cset name=“I2S4 Channels” “16”
amixer -c tegrasndt19xmob cset name=“ADMAIF3 Mux” “I2S4”
amixer -c tegrasndt19xmob cset name=“I2S4 Mux” “ADMAIF3”
amixer -c tegrasndt19xmob cset name=“I2S1 codec master mode” “cbm-cfm”
amixer -c tegrasndt19xmob cset name=“I2S1 codec frame mode” “dsp-a”
amixer -c tegrasndt19xmob cset name=“I2S2 codec master mode” “cbm-cfm”
amixer -c tegrasndt19xmob cset name=“I2S2 codec frame mode” “dsp-a”
amixer -c tegrasndt19xmob cset name=“I2S4 codec master mode” “cbm-cfm”
amixer -c tegrasndt19xmob cset name=“I2S4 codec frame mode” “dsp-a”
arecord test (Xavier slave mode)
nvidia@nvidia-xavier:~/Projects/1_HMC_NVI/nvi_combo$ arecord -D hw:tegrasndt19xmob,0 -c 16 -f S32_LE -r 48000 -d 10 cap.wav
Recording WAVE ‘cap.wav’ : Signed 32 bit Little Endian, Rate 48000 Hz, Channels 16
arecord: pcm_read:2103: read error: Input/output error
nvidia@nvidia-xavier:~/Projects/1_HMC_NVI/nvi_combo$ arecord -D hw:tegrasndt19xmob,1 -c 16 -f S32_LE -r 48000 -d 10 cap.wav
nvidia@nvidia-xavier:~/Projects/1_HMC_NVI/nvi_combo$ arecord -D hw:tegrasndt19xmob,2 -c 16 -f S32_LE -r 48000 -d 10 cap.wav
comment
As you can see above, I2S1(ADMAIF1) and I2S4(ADMAIF3) have pcm_read error like my case.
I2S2(ADMAIF2) is all right.
Please be aware that Xavier is slave and other dsp device is master in our case.
So at this time, I tried Xavier master case.(cbs-cfs)
Of course for this experiment I changed dsp to slave mode. that is, the clock/fs pins of dsp is changed to input property.
The result is like this:
arecord test (Xavier master mode)
At this case, I2S1 only has the same problem.
When I observed bck/fs signal by scope, they remain quiet at I2S1 test. The Xavier seems not to provide clk/fs signal at I2S1 test.
Hello Jon,
Regarding Issue#2:
Register values (I don’t know about this) you asked are as below:
nvidia@nvidia-xavier:~$ sudo ls /sys/kernel/debug/regmap/
2903000.amx hdaudioC0D6-hdaudio tegra186-dspk.0 tegra210-adx.2 tegra210-ope.0
2903100.amx tegra186-admaif tegra186-dspk.1 tegra210-adx.3 tegra210-ope.0-mbdrc
2903200.amx tegra186-afc.0 tegra186-i2s.0 tegra210-axbar tegra210-ope.0-peq
2903300.amx tegra186-afc.1 tegra186-i2s.1 tegra210-dmic.0 tegra210-sfc.0
3990000.mipical tegra186-afc.2 tegra186-i2s.2 tegra210-dmic.1 tegra210-sfc.1
4-003c-power-slave tegra186-afc.3 tegra186-i2s.3 tegra210-dmic.2 tegra210-sfc.2
4-0068 tegra186-afc.4 tegra186-i2s.4 tegra210-dmic.3 tegra210-sfc.3
hdaudioC0D3-hdaudio tegra186-afc.5 tegra186-i2s.5 tegra210-mixer
hdaudioC0D4-hdaudio tegra186-arad tegra210-adx.0 tegra210-mvc.0
hdaudioC0D5-hdaudio tegra186-asrc tegra210-adx.1 tegra210-mvc.1
nvidia@nvidia-xavier:~$ sudo cat /sys/kernel/debug/regmap/tegra210-i2s.1/registers
cat: /sys/kernel/debug/regmap/tegra210-i2s.1/registers: No such file or directory
nvidia@nvidia-xavier:~ sudo cat /sys/kernel/debug/regmap/tegra186-i2s.1/registers 00: 00000000 04: XXXXXXXX 08: 00000000 0c: XXXXXXXX 10: XXXXXXXX 14: 00000003 18: 00000000 1c: 00000000 20: 03ff7700 24: 00000100 28: 0000ffff 2c: 00000000 30: 00000000 34: 00000000 38: 00000000 3c: 00000000 40: 00000000 44: XXXXXXXX 48: 00000000 4c: XXXXXXXX 50: XXXXXXXX 54: 00000003 58: 00000000 5c: 00000000 60: 00ff7700 64: 00000100 68: 0000ffff 6c: 00000000 70: 00000000 74: 00000000 78: 00000000 7c: 00000000 80: 00000001 84: 00000000 88: 00000001 8c: 00000000 90: XXXXXXXX 94: 00000000 98: 00000000 9c: 00000000 a0: 1f101207 a4: 000001ff a8: 0000000f ac: 00000000 b0: 00000000 nvidia@nvidia-xavier:~
Regards,
Lunalovre
I missed one thing to say.
JetPack version we are using now is 4.2 (L4T 32.1).
I will try with latest JetPack (4.2.2 L4T 32.2.1).
Regards,
Lunalovre
Hello Jon,
Regarding Issue#2:
We have just found it is not due to Xavier.
I scoped clk/fs and data at the dsp side of level shifter (1.8V <=> 3.3V).
Because of propagation delay of this level shifter, I think I got such result.
If you cannot find any error on the register values I provided, let us close this issue#2.
Sorry for the confusion, Please pay attention to Issue#1 only. Thank you in advance.
Regards,
Lunalovre
Hello Jon,
Regarding Issue#1:
Meantime I have been trying again with new Xavier module and JetPack 4.2.2.
From the scratch, I have checked your asking test (arecord test) at each step.
Before modifying dts file and master mode at DevKit
I2S1 => no input/output error
I2S2 => no error
I2S4 => no error
After modifying dts file and master mode at DevKit
I2S1 => error
I2S2 => no error
I2S4 => no error
After modifying dts file and slave mode at target board
I2S1 => error
I2S2 => no error
I2S4 => no error
From above, there are two kinds of new information.
At dev kit, without modifying dts, there seems no error.
But, as modifying dts, probably removing audio codec incompletely (my assumption) may cause the error.
I cannot find I2S4 error which I experienced at JetPack 4.2.
However I am not sure it is due to which one among JetPack version, different module, or my unknowing dts change items.
I will go over this. Please ignore I2S4 error.
Finally please pay attention to I2S1 error occuring when I use that channel at my use case rather than for codec ic.
Regards
Lunalovre
Hello!
For the I2S1 error case when Xavier is the slave can you send the output from the following commands …
$ sudo grep dap1 /sys/kernel/debug/tegra_pinctrl_reg
And …
echo 0 | sudo tee /sys/kernel/debug/tracing/trace
echo 0 | sudo tee /sys/kernel/debug/tracing/events/enable
echo 1 | sudo tee /sys/kernel/debug/tracing/tracing_on
echo 1 | sudo tee /sys/kernel/debug/tracing/events/asoc/snd_soc_dapm_widget_power/enable
arecord ...
sudo cat /sys/kernel/debug/tracing/trace
Regards,
Jon
Hello Jon
The followings are what you asked.
nvidia@nvidia-xavier:~/Projects/1_HMC_NVI/nvi_combo$ sudo grep dap1 /sys/kernel/debug/tegra_pinctrl_reg
Bank: 0 Reg: 0x02431028 Val: 0x00000440 -> dap1_fs_ps3
Bank: 0 Reg: 0x02431030 Val: 0x00000454 -> dap1_din_ps2
Bank: 0 Reg: 0x02431038 Val: 0x00000400 -> dap1_dout_ps1
Bank: 0 Reg: 0x02431040 Val: 0x00000440 -> dap1_sclk_ps0
nvidia@nvidia-xavier:~/Projects/1_HMC_NVI/nvi_combo$ echo 0 | sudo tee /sys/kernel/debug/tracing/trace
0
nvidia@nvidia-xavier:~/Projects/1_HMC_NVI/nvi_combo$ echo 0 | sudo tee /sys/kernel/debug/tracing/events/enable
0
nvidia@nvidia-xavier:~/Projects/1_HMC_NVI/nvi_combo$ echo 1 | sudo tee /sys/kernel/debug/tracing/tracing_on
1
nvidia@nvidia-xavier:~/Projects/1_HMC_NVI/nvi_combo$ echo 1 | sudo tee /sys/kernel/debug/tracing/events/asoc/snd_soc_dapm_widget_power/enable
1
nvidia@nvidia-xavier:~/Projects/1_HMC_NVI/nvi_combo$ arecord -D hw:tegrasndt19xmob,0 -c 16 -f S16_LE -r 48000 -d 10 cap.wav
Recording WAVE ‘cap.wav’ : Signed 16 bit Little Endian, Rate 48000 Hz, Channels 16
nvidia@nvidia-xavier:~/Projects/1_HMC_NVI/nvi_combo$ sudo cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 0/0 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
For me, it seems strange (contents are blank?) so I tried for success case of I2S2.
nvidia@nvidia-xavier:~/Projects/1_HMC_NVI/nvi_combo$ arecord -D hw:tegrasndt19xmob,1 -c 16 -f S16_LE -r 48000 -d 10 cap.wav
tracer: nop
entries-in-buffer/entries-written: 30/30 #P:4
_-----=> irqs-off
||| / delay
     arecord-8611  [001] ....   780.104557: snd_soc_dapm_widget_power: widget=Capture 2 val=1
     arecord-8611  [001] ....   780.104570: snd_soc_dapm_widget_power: widget=ADMAIF2 Transmit val=1
     arecord-8611  [001] ....   780.104574: snd_soc_dapm_widget_power: widget=ADMAIF2 TX val=1
     arecord-8611  [001] ....   780.104576: snd_soc_dapm_widget_power: widget=ADMAIF2 Mux val=1
     arecord-8611  [001] ....   780.104610: snd_soc_dapm_widget_power: widget=I2S2 RX val=1
     arecord-8611  [001] ....   780.104613: snd_soc_dapm_widget_power: widget=I2S2 Receive val=1
     arecord-8611  [001] ....   780.104616: snd_soc_dapm_widget_power: widget=I2S2 CIF Transmit-I2S2 Receive val=1
     arecord-8611  [001] ....   780.104618: snd_soc_dapm_widget_power: widget=I2S2 CIF Transmit val=1
     arecord-8611  [001] ....   780.104620: snd_soc_dapm_widget_power: widget=I2S2 CIF TX val=1
     arecord-8611  [001] ....   780.104622: snd_soc_dapm_widget_power: widget=I2S2 DAP RX val=1
     arecord-8611  [001] ....   780.104624: snd_soc_dapm_widget_power: widget=I2S2 DAP Receive val=1
     arecord-8611  [001] ....   780.104626: snd_soc_dapm_widget_power: widget=y Capture-I2S2 DAP Receive val=1
     arecord-8611  [001] ....   780.104629: snd_soc_dapm_widget_power: widget=y Capture val=1
     arecord-8611  [001] ....   780.104637: snd_soc_dapm_widget_power: widget=y IN val=1
     arecord-8611  [001] ....   780.104639: snd_soc_dapm_widget_power: widget=y Mic val=1
     arecord-8611  [000] ....   790.107698: snd_soc_dapm_widget_power: widget=Capture 2 val=0
     arecord-8611  [000] ....   790.107710: snd_soc_dapm_widget_power: widget=ADMAIF2 Transmit val=0
     arecord-8611  [000] ....   790.107713: snd_soc_dapm_widget_power: widget=ADMAIF2 TX val=0
     arecord-8611  [000] ....   790.107715: snd_soc_dapm_widget_power: widget=ADMAIF2 Mux val=0
     arecord-8611  [000] ....   790.107749: snd_soc_dapm_widget_power: widget=I2S2 RX val=0
     arecord-8611  [000] ....   790.107752: snd_soc_dapm_widget_power: widget=I2S2 Receive val=0
     arecord-8611  [000] ....   790.107755: snd_soc_dapm_widget_power: widget=I2S2 CIF Transmit-I2S2 Receive val=0
     arecord-8611  [000] ....   790.107757: snd_soc_dapm_widget_power: widget=I2S2 CIF Transmit val=0
     arecord-8611  [000] ....   790.107760: snd_soc_dapm_widget_power: widget=I2S2 CIF TX val=0
     arecord-8611  [000] ....   790.107762: snd_soc_dapm_widget_power: widget=I2S2 DAP RX val=0
     arecord-8611  [000] ....   790.107764: snd_soc_dapm_widget_power: widget=I2S2 DAP Receive val=0
     arecord-8611  [000] ....   790.107766: snd_soc_dapm_widget_power: widget=y Capture-I2S2 DAP Receive val=0
     arecord-8611  [000] ....   790.107769: snd_soc_dapm_widget_power: widget=y Capture val=0
     arecord-8611  [000] ....   790.107771: snd_soc_dapm_widget_power: widget=y IN val=0
     arecord-8611  [000] ....   790.107773: snd_soc_dapm_widget_power: widget=y Mic val=0
Regards,
Lunalovre
Hello!
Yes if the contents are blank that is not good indeed. That implies that there is a problem with the audio routing.
Can you share the modified DTS file and also the complete bootlog (ie. dmesg output after booting).
Jon
Hello Jon,
The following is my dts file (tegra194-audio-p2822-0000.dtsi)
The modified points are indicated by comment of “org” and “weacom”.
 * T194 p2822-0000 audio common DTSI file.
 * Copyright (c) 2017, NVIDIA CORPORATION.  All rights reserved.
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; version 2 of the License.
 * This program is distributed in the hope that it will be useful, but WITHOUT
 * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
 * FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
 * more details.
#include <audio/tegra-platforms-audio-dai-links.dtsi>
#include <t19x-common-platforms/tegra194-platforms-audio-pinmux.dtsi>
#include <dt-bindings/gpio/tegra194-gpio.h>
#include <dt-bindings/sound/rt5659.h>
	aconnect@2a41000 {
		status = "okay";
		agic-controller@2a41000 {
			status = "okay";
		adsp@2993000 {
			status = "okay";
	i2c@c250000 {
			compatible = "realtek,rt5658";
			reg = <0x1a>;
			realtek,dmic2-data-pin = <RT5659_DMIC2_NULL>;
#if 0 //weacom
	aconnect@2a41000 {
		ahub {
			i2s@2901300 {
				fsync-width = <0>;
#endif
	hda@3510000 {
		status = "okay";
	tegra_sound: sound {
		status = "okay";
		compatible = "nvidia,tegra-audio-t186ref-mobile-rt565x";
		nvidia,model = "tegra-snd-t19x-mobile-rt565x";
		clocks = <&bpmp_clks TEGRA194_CLK_PLLP_OUT0>,
			<&bpmp_clks TEGRA194_CLK_PLLA>,
			<&bpmp_clks TEGRA194_CLK_PLLA_OUT0>,
			<&bpmp_clks TEGRA194_CLK_AHUB>,
			<&bpmp_clks TEGRA194_CLK_CLK_M>,
			<&bpmp_clks TEGRA194_CLK_AUD_MCLK>;
		clock-names = "pll_p_out1", "pll_a", "pll_a_out0", "ahub",
			"clk_m", "extern1";
		nvidia,audio-routing =
			"x Headphone Jack",     "x HPO L Playback",
			"x Headphone Jack",     "x HPO R Playback",
			"x IN1P",               "x Mic Jack",
			"x IN2P",               "x Mic Jack",
			"x Int Spk",            "x SPO Playback",
			"x DMIC L1",            "x Int Mic",
			"x DMIC L2",            "x Int Mic",
			"x DMIC R1",            "x Int Mic",
			"x DMIC R2",            "x Int Mic",
			"y Headphone",          "y OUT",
			"y IN",                 "y Mic",
			"z Headphone",          "z OUT",
			"z IN",                 "z Mic",
			"m Headphone",          "m OUT",
			"m IN",                 "m Mic",
			"n Headphone",          "n OUT",
			"n IN",                 "n Mic",
			"o Headphone",          "o OUT",
			"o IN",                 "o Mic",
			"a IN",                 "a Mic",
			"b IN",                 "b Mic",
			"c IN",                 "c Mic",
			"d IN",                 "d Mic",
			"d1 Headphone",         "d1 OUT",
			"d2 Headphone",         "d2 OUT";
			/* Default config for all I2S dai links are
			format = "i2s", bitclock-slave, frame-slave,
			bitclock-noninversion, frame-noninversion,
			bclk_ratio = 1 , Any change from default needs
			override on platform specific files. */
			/* Override with Codec entries */
/* org
			nvidia,dai-link-1 {
				link-name = "rt565x-playback";
				codec-dai-name = "rt5659-aif1";
			/* Override with BT SCO entries */
/* org
			nvidia,dai-link-4 {
				format = "dsp_a";
				tx-mask = <0xFF>;
				rx-mask = <0xFF>;
				bitclock-inversion;
				bclk_ratio = <4>;
				srate = <8000>;
				num-channel = <1>;
			/* Override by weacom from here */
			nvidia,dai-link-1 {
				link-name = "spdif-dit-0";
				cpu-dai = <&tegra_i2s1>;
				codec-dai = <&spdif_dit0>;
				cpu-dai-name = "I2S1";
				codec-dai-name = "dit-hifi";
				format = "dsp_a";	/*org: "i2s";*/
				bitclock-master; 	/*org: none*/
				frame-master; 		/*org: none*/
				bitclock-inversion;	/*org: none*/
				frame-noninversion;	/*org: none*/
				bit-format = "s32_le";	/*org: "s16_le";*/
				bclk_ratio = <1>;
				srate = <48000>;
				num-channel = <16>;	/*org: <2>;*/
				tx-mask=<0xFFFF>;	/*org: none*/
				rx-mask=<0xFFFF>;	/*org: none*/
				ignore_suspend;
				name-prefix = "x";
				status = "okay";
			nvidia,dai-link-2 {
				link-name = "spdif-dit-1";
				cpu-dai-name = "I2S2";
				bclk_ratio = <1>;
				srate = <48000>;
				ignore_suspend;
				name-prefix = "y";
				status = "okay";
			nvidia,dai-link-4 {
				link-name = "spdif-dit-3";
				cpu-dai = <&tegra_i2s4>;
				codec-dai = <&spdif_dit3>;
				cpu-dai-name = "I2S4";
				bclk_ratio = <1>;
				srate = <48000>;
				ignore_suspend;
				name-prefix = "m";
				status = "okay";
			/* Override by weacom upto here */
Regards,
Lunalovre
And …
The bootlog is as follows:
[code]
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-770) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Aug 12 21:29:52 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2b000000
[ 0.000000] OF: fdt: - ab200000 , 3d800000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a0697000
[ 0.000000] Found lut_mem: 00002008@a0693000
[ 0.000000] Found vpr, start=0xf0000000 size=8000000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000e4800000
[ 0.000000] On node 0 totalpages: 4095485
[ 0.000000] DMA zone: 6648 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 425469 pages, LIFO batch:31
[ 0.000000] Normal zone: 57344 pages used for memmap
[ 0.000000] Normal zone: 3670016 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc3ffd95000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4031493
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0697000 lut_mem=0x2008@0xa0693000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29212(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 15987120K/16381940K available (15230K kernel code, 2914K rwdata, 6628K rodata, 8576K init, 609K bss, 329284K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a118808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a118808 - 0xffffff800a1b0dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000015] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009896] Console: colour dummy device 80x25
[ 0.012684] console [tty0] enabled
[ 0.016151] bootconsole [tegra_comb_uart0] disabled
[ 0.020896] kmemleak: Kernel memory leak detector disabled
[ 0.020990] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.021079] pid_max: default: 32768 minimum: 301
[ 0.022464] Security Framework initialized
[ 0.023230] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.023303] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.025548] ftrace: allocating 46938 entries in 184 pages
[ 0.507626] sched-energy: Sched-energy-costs installed from DT
[ 0.507846] ASID allocator initialised with 65536 entries
[ 0.549215] tegra-id: chipid=21917.
[ 0.549261] tegra-id: opt_subrevision=0.
[ 0.549351] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.549424] DTS File Name: /home/jjh/nvidia/nvidia_sdk/JetPack_4.2.2_XAV_Target/CrossBuild/sources/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.549575] DTB Build time: Oct 5 2019 06:05:28
[ 0.599177] CPU1: Booted secondary processor [4e0f0040]
[ 0.631386] CPU2: Booted secondary processor [4e0f0040]
[ 0.663802] CPU3: Booted secondary processor [4e0f0040]
[ 0.696219] CPU4: Booted secondary processor [4e0f0040]
[ 0.728346] CPU5: Booted secondary processor [4e0f0040]
[ 0.761030] CPU6: Booted secondary processor [4e0f0040]
[ 0.793069] CPU7: Booted secondary processor [4e0f0040]
[ 0.793444] Brought up 8 CPUs
[ 0.793802] SMP: Total of 8 processors activated.
[ 0.793849] CPU features: detected feature: Privileged Access Never
[ 0.793890] CPU features: detected feature: LSE atomic instructions
[ 0.793931] CPU features: detected feature: User Access Override
[ 0.793970] CPU features: detected feature: 32-bit EL0 Support
[ 0.796588] CPU: All CPU(s) started at EL2
[ 0.796700] alternatives: patching kernel code
[ 0.806780] devtmpfs: initialized
[ 0.891278] Initilizing CustomIPI irq domain
[ 0.891706] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.891782] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.893800] pinctrl core: initialized pinctrl subsystem
[ 0.894058] OS set in device tree is not L4T.
[ 0.894383] regulator-dummy: no parameters
[ 0.894776] Initializing plugin-manager
[ 0.894855] Plugin module not found
[ 0.894918] Plugin-manager status disabled
[ 0.896590] NET: Registered protocol family 16
[ 0.898538] pstore: using zlib compression
[ 0.899973] console [pstore-1] enabled
[ 0.900052] pstore: Registered ramoops as persistent store backend
[ 0.900125] ramoops: attached 0x200000@0xe8800000, ecc: 0/0
[ 0.920252] cpuidle: using governor menu
[ 0.921799] bpmp: waiting for handshake
[ 0.921858] bpmp: handshake completed
[ 0.921921] bpmp: synchronizing channels
[ 0.921969] bpmp: channels synchronized
[ 0.922013] bpmp: mail init ok
[ 0.925953] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.926265] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.926321] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.926364] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.926408] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.926484] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.926543] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.926606] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.926704] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.926753] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.926801] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.931849] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.932150] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.936734] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.938367] Registering BPMP clocks…
[ 0.938594] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.939467] tegra_powergate_init: DONE
[ 0.939686] DTS File Name: /home/jjh/nvidia/nvidia_sdk/JetPack_4.2.2_XAV_Target/CrossBuild/sources/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.939916] DTB Build time: Oct 5 2019 06:05:28
[ 0.943715] Tegra reboot handler registered.
[ 0.952886] iommu: Adding device 14180000.pcie to group 0
[ 0.953855] iommu: Adding device 14100000.pcie to group 1
[ 0.954814] iommu: Adding device 14140000.pcie to group 2
[ 0.955664] iommu: Adding device 141a0000.pcie to group 3
[ 0.957824] iommu: Adding device 2490000.ether_qos to group 4
[ 0.958584] iommu: Adding device 3100000.serial to group 5
[ 0.959307] iommu: Adding device 3110000.serial to group 6
[ 0.959849] iommu: Adding device 3140000.serial to group 7
[ 0.960636] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.960946] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.961045] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.961127] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.961224] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.961334] tegra-pmc: PMC Prod config success
[ 0.961637] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.961740] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.962289] iommu: Adding device 3460000.sdhci to group 8
[ 0.963086] iommu: Adding device 3400000.sdhci to group 9
[ 0.963858] iommu: Adding device 2450000.ufshci to group 10
[ 0.964878] iommu: Adding device c260000.spi to group 11
[ 0.966077] iommu: Adding device 3160000.i2c to group 12
[ 0.966658] iommu: Adding device c240000.i2c to group 13
[ 0.967202] iommu: Adding device 3180000.i2c to group 14
[ 0.967723] iommu: Adding device 3190000.i2c to group 15
[ 0.968391] iommu: Adding device 31b0000.i2c to group 16
[ 0.968952] iommu: Adding device 31c0000.i2c to group 17
[ 0.969513] iommu: Adding device c250000.i2c to group 18
[ 0.970058] iommu: Adding device 31e0000.i2c to group 19
[ 0.971117] iommu: Adding device sound to group 20
[ 0.971809] iommu: Adding device 3510000.hda to group 21
[ 0.972522] iommu: Adding device bc00000.rtcpu to group 22
[ 0.974984] iommu: Adding device 13e10000.host1x to group 23
[ 0.975537] iommu: Adding device 13e10000.host1x:ctx0 to group 24
[ 0.976130] iommu: Adding device 13e10000.host1x:ctx1 to group 25
[ 0.976690] iommu: Adding device 13e10000.host1x:ctx2 to group 26
[ 0.977299] iommu: Adding device 13e10000.host1x:ctx3 to group 27
[ 0.977847] iommu: Adding device 13e10000.host1x:ctx4 to group 28
[ 0.978423] iommu: Adding device 13e10000.host1x:ctx5 to group 29
[ 0.978972] iommu: Adding device 13e10000.host1x:ctx6 to group 30
[ 0.979536] iommu: Adding device 13e10000.host1x:ctx7 to group 31
[ 0.980283] iommu: Adding device 15340000.vic to group 32
[ 0.980900] iommu: Adding device 15380000.nvjpg to group 33
[ 0.981370] iommu: Adding device 15500000.tsec to group 34
[ 0.981755] iommu: Adding device 15100000.tsecb to group 35
[ 0.982145] iommu: Adding device 15480000.nvdec to group 36
[ 0.982598] iommu: Adding device 15140000.nvdec1 to group 37
[ 0.983018] iommu: Adding device 154c0000.nvenc to group 38
[ 0.983398] iommu: Adding device 15a80000.nvenc1 to group 39
[ 0.983916] iommu: Adding device 15880000.nvdla0 to group 40
[ 0.984495] iommu: Adding device 158c0000.nvdla1 to group 41
[ 0.985251] iommu: Adding device 15200000.nvdisplay to group 42
[ 0.985643] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0697000(800000)
[ 0.985733] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0693000(3000)
[ 0.987022] platform 15200000.nvdisplay: IOVA linear map 0x00000000f0000000(8000000)
[ 0.987110] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.987694] iommu: Adding device 15210000.nvdisplay to group 43
[ 0.987814] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.988350] iommu: Adding device 15220000.nvdisplay to group 44
[ 0.988465] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[ 0.990824] iommu: Adding device 15c10000.vi to group 45
[ 0.991110] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.991638] iommu: Adding device 14800000.isp to group 46
[ 0.993235] iommu: Adding device 16000000.pva0 to group 47
[ 0.993962] iommu: Adding device 16800000.pva1 to group 48
[ 0.994518] iommu: Adding device 15810000.se to group 49
[ 0.995051] iommu: Adding device 15820000.se to group 50
[ 0.995436] iommu: Adding device 15830000.se to group 51
[ 0.995879] iommu: Adding device 15840000.se to group 52
[ 0.996250] iommu: Adding device c1a0000.aon to group 53
[ 0.997939] iommu: Adding device d000000.bpmp to group 54
[ 0.998442] bpmp: ping status is 0
[ 0.998643] bpmp d000000.bpmp: firmware tag is c1b4e372932429f2737cf722e1219e71
[ 1.002540] bpmp d000000.bpmp: probe ok
[ 1.004251] tegra-reset 0.bpmp_reset: registered 186 resets.
[ 1.004915] iommu: Adding device smmu_test to group 55
[ 1.006249] mc: mapped MMIO address: 0xffffff800a580000 -> 0x2c10000
[ 1.006337] mc: mapped MMIO address: 0xffffff800a5a0000 -> 0x2c20000
[ 1.006417] mc: mapped MMIO address: 0xffffff800a5c0000 -> 0x2c30000
[ 1.006523] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c40000
[ 1.006605] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c50000
[ 1.006686] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2b80000
[ 1.006768] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2b90000
[ 1.006846] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2ba0000
[ 1.006923] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2bb0000
[ 1.007001] mc: mapped MMIO address: 0xffffff800b070000 -> 0x1700000
[ 1.007079] mc: mapped MMIO address: 0xffffff800b090000 -> 0x1710000
[ 1.007156] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1720000
[ 1.007233] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1730000
[ 1.007310] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1740000
[ 1.007386] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1750000
[ 1.007460] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1760000
[ 1.007559] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1770000
[ 1.007778] mc-err: mcerr ops are set to t19x
[ 1.015051] iommu: Adding device 2600000.dma to group 56
[ 1.021882] GPIO line 490 (pcie-reg-enable) hogged as output/high
[ 1.022035] GPIO line 289 (pcie-reg-enable) hogged as output/high
[ 1.022153] GPIO line 339 (wifi-enable) hogged as output/high
[ 1.022600] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.029999] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 1.030405] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.032791] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.032856] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.033871] iommu: Adding device 3550000.xudc to group 57
[ 1.034814] iommu: Adding device 3610000.xhci to group 58
[ 1.037729] arm64_ras arm64_ras: probed
[ 1.038316] ras_fhi_enable: FHI 477 enabled on CPU0
[ 1.038418] ras_fhi_enable: FHI 478 enabled on CPU1
[ 1.038628] ras_fhi_enable: FHI 479 enabled on CPU2
[ 1.038775] ras_fhi_enable: FHI 480 enabled on CPU3
[ 1.038897] ras_fhi_enable: FHI 481 enabled on CPU4
[ 1.039021] ras_fhi_enable: FHI 482 enabled on CPU5
[ 1.039220] ras_fhi_enable: FHI 483 enabled on CPU6
[ 1.039345] ras_fhi_enable: FHI 484 enabled on CPU7
[ 1.039666] carmel_ras_enable: RAS enabled on cpu0
[ 1.040000] carmel_ras_enable: RAS enabled on cpu1
[ 1.040324] carmel_ras_enable: RAS enabled on cpu2
[ 1.040660] carmel_ras_enable: RAS enabled on cpu3
[ 1.040971] carmel_ras_enable: RAS enabled on cpu4
[ 1.041225] carmel_ras_enable: RAS enabled on cpu5
[ 1.041496] carmel_ras_enable: RAS enabled on cpu6
[ 1.041768] carmel_ras_enable: RAS enabled on cpu7
[ 1.041939] carmel_ras carmel_ras: probed
[ 1.043513] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 1.044190] tegra-cbb c600000.aon-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
[ 1.045271] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 490, noc_nonsecure_irq = 489>
[ 1.046408] tegra-cbb be00000.rce-noc: noc_secure_irq = 492, noc_nonsecure_irq = 491>
[ 1.047646] tegra-cbb b600000.sce-noc: noc_secure_irq = 494, noc_nonsecure_irq = 493>
[ 1.048183] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.051253] vdd-3v3-cvb: 3300 mV
[ 1.051657] vdd-1v8-cvb: 1800 mV
[ 1.052212] vdd-1v8-sd: 1800 mV
[ 1.052714] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.052851] vdd-epb-1v0: 1000 mV
[ 1.053263] vdd-sdmmc1-sw: 3300 mV
[ 1.053686] avdd-cam-2v8: 2800 mV
[ 1.054051] vdd-sata-1v5: 1500 mV
[ 1.054413] vdd-1v8-slt: 1800 mV
[ 1.054758] vdd-3v3-slt: 3300 mV
[ 1.055125] vdd-fan: 5000 mV
[ 1.055532] vdd-hdmi-5v0: 5000 mV
[ 1.056052] vdd_sys_en: 1200 mV
[ 1.056569] vdd-5v-sata: 5000 mV
[ 1.057038] vdd-ac-bat: 5000 mV
[ 1.057271] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.093249] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.098965] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.099408] SCSI subsystem initialized
[ 1.099902] libata version 3.00 loaded.
[ 1.100148] usbcore: registered new interface driver usbfs
[ 1.100264] usbcore: registered new interface driver hub
[ 1.100484] usbcore: registered new device driver usb
[ 1.112832] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.115961] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.122311] vdd-1v0: at 1000 mV
[ 1.126421] vdd-1v8-hs: at 1800 mV
[ 1.130460] vdd-1v8-ls: at 1800 mV
[ 1.134521] vdd-1v8-ao: at 1800 mV
[ 1.138593] vddio-ddr-1v1: at 1100 mV
[ 1.142365] vdd-rtc: at 800 mV
[ 1.143856] spmic-ldo1: at 2375 mV
[ 1.150465] vdd-ao-3v3: at 3300 mV
[ 1.158530] vddio-emmc-3v3: at 3300 mV
[ 1.160104] spmic-ldo4: at 1587 mV
[ 1.166649] vdd-usb-3v3: at 3300 mV
[ 1.174740] vddio-sdmmc1-3v3: at 3300 mV
[ 1.178791] vdd-csi-1v2: at 1200 mV
[ 1.180587] spmic-ldo8: at 1800 mV
[ 1.182788] GPIO line 246 (gpio_default) hogged as output/high
[ 1.184372] GPIO line 247 (gpio_default) hogged as output/high
[ 1.184837] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.188384] max77620 4-003c: max77620 probe successful
[ 1.189145] media: Linux media interface: v0.10
[ 1.189245] Linux video capture interface: v2.00
[ 1.191046] pps_core: LinuxPPS API ver. 1 registered
[ 1.191090] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.191188] PTP clock support registered
[ 1.191892] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.191974] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.193438] tegra_fiq_debugger_init: found FIQ source (IRQ 469)
[ 1.196981] trusty trusty: trusty version: Built: 21:17:12 Aug 12 2019
[ 1.197107] trusty trusty: selected api version: 3 (requested 3)
[ 1.198573] Advanced Linux Sound Architecture Driver Initialized.
[ 1.199236] Bluetooth: Core ver 2.22
[ 1.199317] NET: Registered protocol family 31
[ 1.199357] Bluetooth: HCI device and connection manager initialized
[ 1.199412] Bluetooth: HCI socket layer initialized
[ 1.199457] Bluetooth: L2CAP socket layer initialized
[ 1.199524] Bluetooth: SCO socket layer initialized
[ 1.202704] camchar: rtcpu character device driver loaded
[ 1.205208] clocksource: Switched to clocksource arch_sys_counter
[ 1.269624] VFS: Disk quotas dquot_6.6.0
[ 1.269860] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.270329] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.272318] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.272459] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000f0000000,134217728
[ 1.272532] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.272579] nvmap_page_pool_init: Total RAM pages: 4013164
[ 1.272618] nvmap_page_pool_init: nvmap page pool size: 501645 pages (1959 MB)
[ 1.272988] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.273496] misc nvmap: created heap vpr base 0x00000000f0000000 size (131072KiB)
[ 1.275260] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.293481] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.293804] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.294110] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.294425] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.294906] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 1.295266] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 1.295437] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 1.296951] la/ptsa driver initialized.
[ 1.297529] NET: Registered protocol family 2
[ 1.298730] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.299644] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.300429] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.300523] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.300849] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.301693] NET: Registered protocol family 1
[ 1.302596] RPC: Registered named UNIX socket transport module.
[ 1.302651] RPC: Registered udp transport module.
[ 1.302686] RPC: Registered tcp transport module.
[ 1.302721] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.302793] PCI: CLS 0 bytes, default 64
[ 1.303047] Trying to unpack rootfs image as initramfs…
[ 1.534169] Freeing initrd memory: 5432K
[ 1.552120] random: fast init done
[ 1.558218] host1x 13e10000.host1x: initialized
[ 1.561265] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.567382] audit: initializing netlink subsys (disabled)
[ 1.567483] audit: type=2000 audit(1.100:1): initialized
[ 1.568484] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.578688] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.580182] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.580981] 9p: Installing v9fs 9p2000 file system support
[ 1.587365] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.587630] io scheduler noop registered
[ 1.587943] io scheduler cfq registered (default)
[ 1.592111] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.632521] iommu: Adding device 2993000.adsp to group 59
[ 1.735729] iommu: Adding device aconnect@2a41000:adsp_audio to group 60
[ 1.736793] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.751782] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.752327] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.753040] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.753535] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.756957] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.757315] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.757387] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 1.762271] tsec 15500000.tsec: initialized
[ 1.764846] tsec 15100000.tsecb: initialized
[ 1.770972] nvdec 15480000.nvdec: initialized
[ 1.775049] nvdec 15140000.nvdec1: initialized
[ 1.782466] falcon 15340000.vic: initialized
[ 1.785039] falcon 15380000.nvjpg: initialized
[ 1.787698] falcon 154c0000.nvenc: initialized
[ 1.790043] falcon 15a80000.nvenc1: initialized
[ 1.794342] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.798248] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.802131] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.804596] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.807031] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.809369] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.811577] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.813812] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.818391] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.824819] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.825328] scare-pigeon 14b00000.isp-thi: initialized
[ 1.835722] pva 16000000.pva0: initialized
[ 1.868064] pva 16800000.pva1: initialized
[ 1.899429] nvdla 15880000.nvdla0: initialized
[ 1.931054] nvdla 158c0000.nvdla1: initialized
[ 1.935221] tegra-slvs-ec 15ac0000.slvs-ec: initialized
[ 1.935445] tegra-slvs-ec 15ac0000.slvs-ec: no streams defined
[ 1.935491] tegra-slvs-ec 15ac0000.slvs-ec: failed to init SLVS media controller (-19)
[ 1.935541] tegra-slvs-ec 15ac0000.slvs-ec: probed
[ 1.936706] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.936759] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.936841] tegradccommon 15200000.dc_common: dma mapping done
[ 1.938054] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.938200] generic_infoframe_type: 0x87
[ 1.938445] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.938548] tegradc 15200000.nvdisplay: Display dc.ffffff800bdd0000 registered with id=0
[ 1.945026] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.945093] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.945216] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.945545] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.945595] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.947319] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.949363] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 1.949993] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.950048] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.950356] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.950964] kfuse 3830000.kfuse: initialized
[ 1.954953] tegradc 15200000.nvdisplay: probed
[ 1.964307] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.967937] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
[ 1.969539] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 1.970818] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 4.478105] console [ttyTCU0] enabled
[ 4.478761] [drm] Initialized
[ 4.479140] Console: switching to colour frame buffer device 240x67
[ 4.491022] tegradc 15200000.nvdisplay: fb registered
[ 4.496442] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 4.501715] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.507613] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.510157] brd: module loaded
[ 4.516941] loop: module loaded
[ 4.519243] tegra_profiler: version: 1.134, samples/io: 47/26
[ 4.524980] tegra_profiler: auth: init
[ 4.529563] nct1008_nct72 4-004c: starting parse dt
[ 4.530085] THERMAL EST: found 3 subdevs
[ 4.530092] THERMAL EST num_resources: 0
[ 4.530098] [THERMAL EST subdev 0]
[ 4.530104] [THERMAL EST subdev 1]
[ 4.530110] [THERMAL EST subdev 2]
[ 4.530165] THERMAL EST: Found 2 profiles, default profile is quiet
[ 4.530648] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.530652] THERMAL EST: thz register success.
[ 4.530946] THERMAL EST: end of probe, return err: 0
[ 4.535604] Parent Clock set for DC plld3
[ 4.536063] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 4.536075] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.537216] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 459
[ 4.537228] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
[ 4.549330] scsi host0: ufshcd
[ 4.561827] hisi_sas: driver version v1.6
[ 4.567281] libphy: Fixed MDIO Bus: probed
[ 4.567973] tun: Universal TUN/TAP device driver, 1.6
[ 4.567977] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 4.568807] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 4.568811] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 4.568851] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.568854] igb: Copyright © 2007-2014 Intel Corporation.
[ 4.568888] igbvf: Intel® Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.568891] igbvf: Copyright © 2009 - 2012 Intel Corporation.
[ 4.568925] Intel® 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.568929] Copyright© 1999 - 2017 Intel Corporation.
[ 4.578130] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb e4 53
[ 4.578236] libphy: dwc_phy: probed
[ 4.580648] PPP generic driver version 2.4.2
[ 4.580938] PPP BSD Compression module registered
[ 4.580943] PPP Deflate Compression module registered
[ 4.580968] PPP MPPE Compression module registered
[ 4.580973] NET: Registered protocol family 24
[ 4.581030] usbcore: registered new interface driver r8152
[ 4.581074] usbcore: registered new interface driver asix
[ 4.581111] usbcore: registered new interface driver ax88179_178a
[ 4.581205] usbcore: registered new interface driver cdc_ether
[ 4.581241] usbcore: registered new interface driver net1080
[ 4.581271] usbcore: registered new interface driver cdc_subset
[ 4.581299] usbcore: registered new interface driver zaurus
[ 4.581339] usbcore: registered new interface driver cdc_ncm
[ 4.581624] VFIO - User Level meta-driver version: 0.3
[ 4.582821] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.582841] ehci-pci: EHCI PCI platform driver
[ 4.582897] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.582909] ohci-pci: OHCI PCI platform driver
[ 4.582943] ohci-platform: OHCI generic platform driver
[ 4.589782] tegra-xusb 3610000.xhci: No USB port has OTG_CAP
[ 4.593661] usbcore: registered new interface driver uas
[ 4.593744] usbcore: registered new interface driver usb-storage
[ 4.593849] usbcore: registered new interface driver usbserial
[ 4.595401] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 4.595454] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.595482] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 4.596055] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 4.596190] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 4.596234] tegra-xusb 3610000.xhci: irq 472, io mem 0x03610000
[ 4.596547] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.596554] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.596580] usb usb1: Product: xHCI Host Controller
[ 4.596586] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 4.596592] usb usb1: SerialNumber: 3610000.xhci
[ 4.596896] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 4.596910] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 4.597074] hub 1-0:1.0: USB hub found
[ 4.597250] hub 1-0:1.0: 4 ports detected
[ 4.597747] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.597759] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 4.597769] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 4.598027] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.598033] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.598039] usb usb2: Product: xHCI Host Controller
[ 4.598044] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 4.598049] usb usb2: SerialNumber: 3610000.xhci
[ 4.598521] hub 2-0:1.0: USB hub found
[ 4.598582] hub 2-0:1.0: 4 ports detected
[ 4.601025] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.601078] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 4.601936] mousedev: PS/2 mouse device common for all mice
[ 4.602009] usbcore: registered new interface driver xpad
[ 4.622501] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 4.622507] Extcon AUX2(HDMI) enable
[ 4.623134] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 4.623578] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 4.732661] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.734563] Wake73 for irq=42
[ 4.735972] rtc rtc1: alarm rtc device
[ 4.735992] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.736034] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.736302] i2c /dev entries driver
[ 4.739944] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 4.749031] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
[ 4.803616] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
[ 4.803662] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 4.803668] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 4.803857] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
[ 4.803950] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 4.803956] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 4.804328] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
[ 4.804406] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 4.804462] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 4.804789] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
[ 4.804949] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 4.804960] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 4.805339] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 4.805418] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 4.805425] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 4.805754] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
[ 4.806494] FAN dev name: pwm-fan
[ 4.806548] FAN:gpio request success.
[ 4.806587] FAN: can’t find tach_gpio
[ 4.806599] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 4.806672] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 4.806954] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 4.806961] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.807353] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.807360] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
[ 4.807367] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.807373] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.807379] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.807386] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.807392] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.807399] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.807405] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.807411] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.808688] device-mapper: uevent: version 1.0.3
[ 4.809278] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.826555] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 4.831457] cpuidle: Initializing cpuidle driver
[ 4.848772] sdhci: Secure Digital Host Controller Interface driver
[ 4.848775] sdhci: Copyright© Pierre Ossman
[ 4.848777] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.850118] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.852510] CMDQ: cmdq_platfm_init successful
[ 4.853006] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.855036] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.856884] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 254
[ 4.861179] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.862140] tegra-se-nvhost 15810000.se: initialized
[ 4.863358] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.864272] tegra-se-nvhost 15820000.se: initialized
[ 4.865380] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.866139] tegra-se-nvhost 15830000.se: initialized
[ 4.866740] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.867435] tegra-se-nvhost 15840000.se: initialized
[ 4.868239] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.868456] hidraw: raw HID events driver © Jiri Kosina
[ 4.869415] usbcore: registered new interface driver usbhid
[ 4.869417] usbhid: USB HID core driver
[ 4.874650] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 4.875571] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.875931] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.876444] denver_knobs_init:MTS_VERSION:45309758
[ 4.876620] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 4.877310] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.877656] t19x_cache tegra-cache: probed
[ 4.883736] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 4.883758] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 4.901171] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.904551] nvpmodel: initialized successfully
[ 4.909083] trusty-virtio trusty:virtio: initializing
[ 4.909245] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 4.909311] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.909398] trusty_ipc virtio0: vring0: va(pa) ffffffc3ea308000(0) qsz 32 notifyid 1
[ 4.909406] trusty_ipc virtio0: vring1: va(pa) ffffffc3ea30a000(0) qsz 32 notifyid 2
[ 4.909531] trusty-virtio trusty:virtio: initializing done
[ 4.910096] tegra-hda 3510000.hda: Override SDO lines to 4
[ 4.910480] usbcore: registered new interface driver snd-usb-audio
[ 4.910698] trusty_ipc virtio0: is online
[ 4.929735] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.929855] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.929996] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 4.930115] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 4.934938] OPE platform probe
[ 4.935027] OPE platform probe successful
[ 4.937176] usb 1-4: new high-speed USB device number 2 using tegra-xusb
[ 4.957578] usb 1-4: New USB device found, idVendor=1a40, idProduct=0101
[ 4.957583] usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.957586] usb 1-4: Product: USB 2.0 Hub
[ 4.958284] hub 1-4:1.0: USB hub found
[ 4.958347] hub 1-4:1.0: 4 ports detected
[ 4.987181] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 4.997960] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.998054] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.998137] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.998254] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.998376] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.998506] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.998595] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.998696] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.998838] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.998935] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.999018] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.999050] mmc0: periodic cache flush enabled
[ 4.999062] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.999103] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.999177] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.999266] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.999381] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.999450] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.999542] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.999592] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 4.999609] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.999683] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.999746] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.999807] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[ 5.000056] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[ 5.000244] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[ 5.003122] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36 p37
[ 5.008934] tegra-asoc: sound: ASoC: no source widget found for x HPO L Playback
[ 5.008938] tegra-asoc: sound: ASoC: Failed to add route x HPO L Playback -> direct -> x Headphone Jack
[ 5.008963] tegra-asoc: sound: ASoC: no source widget found for x HPO R Playback
[ 5.008966] tegra-asoc: sound: ASoC: Failed to add route x HPO R Playback -> direct -> x Headphone Jack
[ 5.008987] tegra-asoc: sound: ASoC: no sink widget found for x IN1P
[ 5.008990] tegra-asoc: sound: ASoC: Failed to add route x Mic Jack -> direct -> x IN1P
[ 5.009013] tegra-asoc: sound: ASoC: no sink widget found for x IN2P
[ 5.009015] tegra-asoc: sound: ASoC: Failed to add route x Mic Jack -> direct -> x IN2P
[ 5.009039] tegra-asoc: sound: ASoC: no source widget found for x SPO Playback
[ 5.009041] tegra-asoc: sound: ASoC: Failed to add route x SPO Playback -> direct -> x Int Spk
[ 5.009063] tegra-asoc: sound: ASoC: no sink widget found for x DMIC L1
[ 5.009065] tegra-asoc: sound: ASoC: Failed to add route x Int Mic -> direct -> x DMIC L1
[ 5.009086] tegra-asoc: sound: ASoC: no sink widget found for x DMIC L2
[ 5.009089] tegra-asoc: sound: ASoC: Failed to add route x Int Mic -> direct -> x DMIC L2
[ 5.009112] tegra-asoc: sound: ASoC: no sink widget found for x DMIC R1
[ 5.009115] tegra-asoc: sound: ASoC: Failed to add route x Int Mic -> direct -> x DMIC R1
[ 5.009151] tegra-asoc: sound: ASoC: no sink widget found for x DMIC R2
[ 5.009153] tegra-asoc: sound: ASoC: Failed to add route x Int Mic -> direct -> x DMIC R2
[ 5.024146] u32 classifier
[ 5.024148] Actions configured
[ 5.024203] Initializing XFRM netlink socket
[ 5.024587] NET: Registered protocol family 10
[ 5.025217] NET: Registered protocol family 17
[ 5.025228] NET: Registered protocol family 15
[ 5.025267] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 5.025346] Bluetooth: RFCOMM socket layer initialized
[ 5.025362] Bluetooth: RFCOMM ver 1.11
[ 5.025367] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.025373] Bluetooth: HIDP socket layer initialized
[ 5.025387] 9pnet: Installing 9P2000 support
[ 5.025421] Key type dns_resolver registered
[ 5.028457] Registered cp15_barrier emulation handler
[ 5.028474] Registered setend emulation handler
[ 5.030032] registered taskstats version 1
[ 5.030422] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 5.031275] OF: PCI: host bridge /pcie@14180000 ranges:
[ 5.031290] OF: PCI: IO 0x38100000…0x381fffff -> 0x38100000
[ 5.031297] OF: PCI: MEM 0x1b40000000…0x1bffffffff -> 0x40000000
[ 5.031301] OF: PCI: MEM 0x1800000000…0x1b3fffffff -> 0x1800000000
[ 5.269159] usb 1-4.1: new full-speed USB device number 3 using tegra-xusb
[ 5.300257] usb 1-4.1: New USB device found, idVendor=046d, idProduct=c534
[ 5.300261] usb 1-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.300264] usb 1-4.1: Product: USB Receiver
[ 5.300266] usb 1-4.1: Manufacturer: Logitech
[ 5.302746] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-4/1-4.1/1-4.1:1.0/0003:046D:C534.0001/input/input4
[ 5.361603] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-4.1/input0
[ 5.364137] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-4/1-4.1/1-4.1:1.1/0003:046D:C534.0002/input/input5
[ 5.421592] hid-generic 0003:046D:C534.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-4.1/input1
[ 5.501212] usb 1-4.4: new high-speed USB device number 4 using tegra-xusb
[ 5.527363] usb 1-4.4: New USB device found, idVendor=125f, idProduct=dd1a
[ 5.527367] usb 1-4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.527371] usb 1-4.4: Product: ADATA USB Flash Drive
[ 5.527373] usb 1-4.4: Manufacturer: ADATA
[ 5.527376] usb 1-4.4: SerialNumber: 1522717041530063
[ 5.528834] usb-storage 1-4.4:1.0: USB Mass Storage device detected
[ 5.529111] scsi host1: usb-storage 1-4.4:1.0
[ 5.537166] tegra-pcie-dw 14180000.pcie: link is down
[ 5.537268] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 5.537294] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 5.537300] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 5.537304] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[ 5.537307] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[ 5.537350] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 5.537484] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.537723] iommu: Adding device 0000:00:00.0 to group 61
[ 5.537942] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 5.537978] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.538155] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.538160] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[ 5.538245] aer 0000:00:00.0:pcie002: service driver aer loaded
[ 5.538396] pcie_pme 0000:00:00.0:pcie001: unloading service driver pcie_pme
[ 5.538432] aer 0000:00:00.0:pcie002: unloading service driver aer
[ 5.538504] pci_bus 0000:01: busn_res: [bus 01-ff] is released
[ 5.538560] iommu: Removing device 0000:00:00.0 from group 61
[ 5.538577] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[ 5.539701] tegra-pcie-dw 14180000.pcie: PCIe link is not up…!
[ 5.540419] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 5.541157] OF: PCI: host bridge /pcie@14100000 ranges:
[ 5.541172] OF: PCI: IO 0x30100000…0x301fffff -> 0x30100000
[ 5.541178] OF: PCI: MEM 0x1230000000…0x123fffffff -> 0x40000000
[ 5.541199] OF: PCI: MEM 0x1200000000…0x122fffffff -> 0x1200000000
[ 6.052702] tegra-pcie-dw 14100000.pcie: link is down
[ 6.052898] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 6.052903] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 6.052921] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 6.052926] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[ 6.052929] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[ 6.052954] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 6.053099] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 6.053330] iommu: Adding device 0001:00:00.0 to group 61
[ 6.053603] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 6.053624] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.053878] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 6.053884] pcie_pme 0001:00:00.0:pcie001: service driver pcie_pme loaded
[ 6.053986] aer 0001:00:00.0:pcie002: service driver aer loaded
[ 6.054157] pcie_pme 0001:00:00.0:pcie001: unloading service driver pcie_pme
[ 6.054253] aer 0001:00:00.0:pcie002: unloading service driver aer
[ 6.054369] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 6.054461] iommu: Removing device 0001:00:00.0 from group 61
[ 6.054507] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 6.055780] tegra-pcie-dw 14100000.pcie: PCIe link is not up…!
[ 6.056248] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 6.057104] OF: PCI: host bridge /pcie@14140000 ranges:
[ 6.057116] OF: PCI: IO 0x34100000…0x341fffff -> 0x34100000
[ 6.057122] OF: PCI: MEM 0x12b0000000…0x12bfffffff -> 0x40000000
[ 6.057126] OF: PCI: MEM 0x1280000000…0x12afffffff -> 0x1280000000
[ 6.431243] tegradc 15200000.nvdisplay: blank - powerdown
[ 6.431336] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 6.431344] nct1008_nct72 4-004c: success parsing dt
[ 6.431490] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 6.464045] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 6.465389] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 6.481454] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 6.481472] Extcon AUX2(HDMI) disable
[ 6.499325] nct1008_nct72 4-004c: initial LOC temp: 38000
[ 6.499851] nct1008_nct72 4-004c: initial EXT temp: 49750
[ 6.500876] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 6.502512] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 6.506752] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 6.507734] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 6.518586] tegradc 15200000.nvdisplay: unblank
[ 6.520364] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 6.520729] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 6.524364] Parent Clock set for DC plld3
[ 6.531798] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 6.533586] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 6.533599] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 6.563406] tegra-pcie-dw 14140000.pcie: link is down
[ 6.563567] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[ 6.563574] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 6.563580] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 6.563601] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[ 6.563605] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[ 6.563632] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 6.563785] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 6.563940] iommu: Adding device 0003:00:00.0 to group 61
[ 6.564220] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 6.564241] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.564455] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 6.564460] pcie_pme 0003:00:00.0:pcie001: service driver pcie_pme loaded
[ 6.564533] aer 0003:00:00.0:pcie002: service driver aer loaded
[ 6.564694] pcie_pme 0003:00:00.0:pcie001: unloading service driver pcie_pme
[ 6.564775] aer 0003:00:00.0:pcie002: unloading service driver aer
[ 6.564855] pci_bus 0003:01: busn_res: [bus 01-ff] is released
[ 6.564935] iommu: Removing device 0003:00:00.0 from group 61
[ 6.564996] pci_bus 0003:00: busn_res: [bus 00-ff] is released
[ 6.566322] tegra-pcie-dw 14140000.pcie: PCIe link is not up…!
[ 6.566988] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 6.568215] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 6.568229] OF: PCI: IO 0x3a100000…0x3a1fffff -> 0x3a100000
[ 6.568252] OF: PCI: MEM 0x1f40000000…0x1fffffffff -> 0x40000000
[ 6.568256] OF: PCI: MEM 0x1c00000000…0x1f3fffffff -> 0x1c00000000
[ 6.568452] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 6.568455] Extcon AUX2(HDMI) enable
[ 6.951879] scsi 1:0:0:0: Direct-Access ADATA USB Flash Drive 1100 PQ: 0 ANSI: 6
[ 6.953290] sd 1:0:0:0: [sda] 60620800 512-byte logical blocks: (31.0 GB/28.9 GiB)
[ 6.953997] sd 1:0:0:0: [sda] Write Protect is off
[ 6.954002] sd 1:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 6.954701] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 6.962454] sda: sda1
[ 6.965242] sd 1:0:0:0: [sda] Attached SCSI removable disk
[ 7.079926] tegra-pcie-dw 141a0000.pcie: link is down
[ 7.080037] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 7.080045] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 7.080050] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 7.080055] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 7.080078] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 7.080104] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 7.080247] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 7.080506] iommu: Adding device 0005:00:00.0 to group 61
[ 7.080720] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 7.080743] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.080980] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 7.080985] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 7.081063] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 7.081239] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 7.081275] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 7.081345] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 7.081405] iommu: Removing device 0005:00:00.0 from group 61
[ 7.081424] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 7.082853] tegra-pcie-dw 141a0000.pcie: PCIe link is not up…!
[ 7.096495] tegra-cbb 14040000.cv-noc: noc_secure_irq = 98, noc_nonsecure_irq = 97>
[ 7.103737] tegra194-isp5 14800000.isp: initialized
[ 7.114955] tegra194-vi5 15c10000.vi: initialized
[ 7.120853] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@0/endpoint.
[ 7.120859] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@1/endpoint.
[ 7.121445] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 7.121472] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 7.122558] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 7.122982] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 7.122986] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 7.197486] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 7.197805] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 7.197953] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 7.198077] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 7.198392] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 7.198532] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 7.198755] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (69)
[ 7.198758] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 7.199720] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 7.200203] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 7.200233] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 7.201049] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 7.201282] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 7.201334] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 7.201428] input: gpio-keys as /devices/gpio-keys/input/input6
[ 7.201554] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 7.202093] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 7.202118] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 7.202636] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 7.202924] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 7.234447] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:50 UTC (946688450)
[ 7.234963] mmcblk mmc0:0001: Card claimed for testing.
[ 7.273322] bpmp: mounted debugfs mirror
[ 7.278928] vdd-1v8-cvb: disabling
[ 7.278933] vdd-1v8-sd: disabling
[ 7.278935] vdd-epb-1v0: disabling
[ 7.278938] avdd-cam-2v8: disabling
[ 7.278940] vdd-sata-1v5: disabling
[ 7.278942] vdd-3v3-slt: disabling
[ 7.278944] vdd-fan: disabling
[ 7.278946] vdd_sys_en: disabling
[ 7.278953] ALSA device list:
[ 7.278956] #0: tegra-hda-galen-t194 at 0x3518000 irq 68
[ 7.278958] #1: tegra-snd-t19x-mobile-rt565x
[ 8.774050] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 8.774078] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 8.774725] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 8.775026] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 8.775345] Wake76 for irq=199
[ 8.775347] Wake77 for irq=199
[ 8.775349] Wake78 for irq=199
[ 8.775350] Wake79 for irq=199
[ 8.775369] Wake80 for irq=199
[ 8.775371] Wake81 for irq=199
[ 8.775372] Wake82 for irq=199
[ 8.775395] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 8.775399] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 8.877420] usb usb2: usb_suspend_both: status 0
[ 9.208915] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 9.210281] Freeing unused kernel memory: 8576K
[ 9.221179] Extcon HDMI: HPD enabled
[ 9.221232] tegradc 15200000.nvdisplay: hdmi: plugged
[ 9.251996] L4T-INITRD Build DATE: Sat Jan 1 01:00:52 UTC 2000
[ 9.258761] Root device found: mmcblk0p1
[ 9.260974] Found dev node: /dev/mmcblk0p1
[ 9.315790] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.318035] Rootfs mounted over mmcblk0p1
[ 9.338922] Switching from initrd to actual rootfs
[ 9.429306] systemd[1]: System time before build time, advancing clock.
[ 9.451439] ip_tables: © 2000-2006 Netfilter Core Team
[ 9.456205] cgroup: cgroup2: unknown option “nsdelegate”
[ 9.465585] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 9.468984] systemd[1]: Detected architecture arm64.
[ 9.479734] systemd[1]: Set hostname to .
[ 9.539203] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 9.540821] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 9.670242] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.672140] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 9.675351] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.679550] systemd[1]: Created slice System Slice.
[ 9.682713] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.684454] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.688668] systemd[1]: Created slice User and Session Slice.
[ 9.691882] systemd[1]: Listening on Syslog Socket.
[ 9.747145] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 9.771769] gpio tegra-gpio wake44 for gpio=192(Y:0)
[ 9.774211] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 9.774240] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 9.775029] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 9.775391] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 9.818249] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 9.877529] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 9.879251] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 9.881752] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 9.883807] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 10.025458] systemd-journald[2379]: Received request to flush runtime journal from PID 1
[ 10.910078] random: crng init done
[ 10.911974] random: 7
Hello
I think there is a length limit of code which can be loaded here. so I try as attachment.
please find a attached file.
Regards,
Lunalover
bootlog.txt (68.3 KB)
Hello!
So the above routes include the routes for the rt5658 codec which is not enabled and so on the boot I see …
Can you update the routing as follows to remove the codec specific routes …
nvidia,audio-routing =
			"x Headphone",          "x OUT",
			"x IN",                 "x Mic",
			"y Headphone",          "y OUT",
			"y IN",                 "y Mic",
			"z Headphone",          "z OUT",
			"z IN",                 "z Mic",
			"m Headphone",          "m OUT",
			"m IN",                 "m Mic",
			"n Headphone",          "n OUT",
			"n IN",                 "n Mic",
			"o Headphone",          "o OUT",
			"o IN",                 "o Mic",
			"a IN",                 "a Mic",
			"b IN",                 "b Mic",
			"c IN",                 "c Mic",
			"d IN",                 "d Mic",
			"d1 Headphone",         "d1 OUT",
			"d2 Headphone",         "d2 OUT";
Regards,
Jon
Hello Jon,
After applying as you guided, arecord problem has been solved out.
Thank you very much!
However, as next step another strange problem symptom has been found.
At this time, there is an error at aplay test through I2S1.
Please see the command line result.
nvidia@nvidia-xavier:~/Projects/test$ arecord -D hw:tegrasndt19xmob,0 -c 16 -f S16_LE -r 48000 -d 10 cap.wav
Recording WAVE ‘cap.wav’ : Signed 16 bit Little Endian, Rate 48000 Hz, Channels 16
nvidia@nvidia-xavier:~/Projects/test$ aplay -D hw:tegrasndt19xmob,0 test.wav
aplay: main:788: audio open error: Device or resource busy
One strange thing is that I saw OK cases at a couple of booting times, but now most of times it fails with busy message.
Could you know why?
Regards,
Lunalovre
Hello Jon,
I guess I have found the reproduction method for such symptom.
When I muted ubuntu system audio, the symptom seems to disappear.
I assume once system audio uses I2S1 codec, this symptom happens.
If so, do you have any idea for correcting this symptom at our source?
Regards,
Lunalovre
Hello!
It is most likely that pulseaudio is using the device and by muting, pulseaudio is not trying to access it. If you also want to use GUI to control/access the soundcards then you need pulseaudio, otherwise you could remove it completely from the system by uninstalling the pulseaudio package.
Otherwise you could set the HDMI/HDA soundcard (tegrahdagalent1) to be the default sink for audio and then it will not access the I2S sound devices.
Regards,
Jon
Hello Jon,
Thank you very much for your sincere help.
Owing to you I have learned much.
Regards,
Lunalovre
