Description
I build a custom plugin and try to put it inside a loop. The plugin works well without inside ILoop but failed when placed inside ILoop.
Code:
nv::ILoop* loop = network->addLoop();
loop->addTripLimit(*T, nv::TripLimit::kCOUNT);
nv::IIteratorLayer* iter = loop->addIterator(*input, 1);
nv::IConvolutionLayer* conv = network->addConvolutionNd(*iter->getOutput(0),
num_out_channel,
nv::Dims2{ size_kernel, size_kernel },
weightMap[lname + ".weight"], nv::Weights{});
LOG_ASSERT(conv, "add convlution layer failed.");
int padding = (size_kernel-1)/2;
conv->setPaddingNd(nv::Dims2{ padding, padding });
conv->setStrideNd(nv::Dims2{ stride, stride });
conv->setNbGroups(num_group);
nv::IPluginV2Layer* slif_neuron = addSLIFLayer(network, conv->getOutput(0), tau, v_threshold, v_reset, reset_mode);
nv::ILoopOutputLayer* output = loop->addLoopOutput(*slif_neuron->getOutput(0), nv::LoopOutput::kCONCATENATE, 1);
output->setInput(1, *T);
Error:
Skipping tactic 0x0000000000000000 due to Myelin error: PLUGIN_V2 operation not supported within this graph.
Error Code 10: Internal Error (Could not find any implementation for node {ForeignNode[(Unnamed Layer* 0) [Constant]...fc1-shuffle]}.)
Error Code 2: Internal Error (Assertion engine != nullptr failed. )
Environment
TensorRT Version: 8.4
GPU Type: Quadro RTX 6000
Nvidia Driver Version: 520.61.05
CUDA Version: 11.8
CUDNN Version:
Operating System + Version: Ubuntu 18.04
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
