Hi, i need your help
I am using sampleUffSSD example in the tensorrt samples directory but when i import opencv there are bunch of errors appearing.
sudo make -j8
…/Makefile.config:5: CUDA_INSTALL_DIR variable is not specified, using /usr/local/cuda by default, use CUDA_INSTALL_DIR=<cuda_directory> to change.
…/Makefile.config:8: CUDNN_INSTALL_DIR variable is not specified, using $CUDA_INSTALL_DIR by default, use CUDNN_INSTALL_DIR=<cudnn_directory> to change.
Compiling: sampleUffSSD.cpp
sampleUffSSD.cpp:124:32: error: template argument 2 is invalid
std::vector<std::pair<int64_t, DataType>>
sampleUffSSD.cpp:124:40: error: template argument 1 is invalid
sampleUffSSD.cpp:124:40: error: template argument 2 is invalid
sampleUffSSD.cpp: In function ‘int calculateBindingBufferSizes(const nvinfer1::ICudaEngine&, int, int)’:
sampleUffSSD.cpp:127:36: error: template argument 2 is invalid
std::vector<std::pair<int64_t, DataType>> sizes;
sampleUffSSD.cpp:127:44: error: template argument 1 is invalid
sampleUffSSD.cpp:127:44: error: template argument 2 is invalid
sampleUffSSD.cpp:131:9: error: reference to ‘DataType’ is ambiguous
DataType dtype = engine.getBindingDataType(i);
In file included from /usr/include/opencv2/core.hpp:56:0,
from /usr/include/opencv2/opencv.hpp:52,
from sampleUffSSD.cpp:1:
/usr/include/opencv2/core/traits.hpp:112:30: note: candidates are: template class cv::DataType
template class DataType
In file included from BatchStreamPPM.h:8:0,
from sampleUffSSD.cpp:13:
/usr/include/aarch64-linux-gnu/NvInfer.h:122:12: note: enum class nvinfer1::DataType
enum class DataType : int
sampleUffSSD.cpp:134:15: error: request for member ‘push_back’ in ‘sizes’, which is of non-class type ‘int’
sizes.push_back(std::make_pair(eltCount, dtype));
sampleUffSSD.cpp:134:50: error: ‘dtype’ was not declared in this scope
sampleUffSSD.cpp:134:50: note: suggested alternative: ‘wctype’
wctype
sampleUffSSD.cpp: In function ‘void doInference(nvinfer1::IExecutionContext&, float*, float*, int*, int)’:
sampleUffSSD.cpp:211:36: error: template argument 2 is invalid
std::vector<std::pair<int64_t, DataType>> buffersSizes = calculateBindingBufferSizes(engine, nbBindings, batchSize);
sampleUffSSD.cpp:211:44: error: template argument 1 is invalid
sampleUffSSD.cpp:211:44: error: template argument 2 is invalid
sampleUffSSD.cpp:215:48: error: invalid types ‘int[int]’ for array subscript
auto bufferSizesOutput = buffersSizes[i];
sampleUffSSD.cpp: At global scope:
sampleUffSSD.cpp:454:25: error: reference to ‘DataType’ is ambiguous
bool supportsFormat(DataType type, PluginFormat format) const override
sampleUffSSD.cpp:454:25: error: ‘DataType’ has not been declared
sampleUffSSD.cpp:454:10: error: ‘bool FlattenConcat::supportsFormat(int, nvinfer1::PluginFormat) const’ marked ‘override’, but does not override
sampleUffSSD.cpp: In member function ‘bool FlattenConcat::supportsFormat(int, nvinfer1::PluginFormat) const’:
sampleUffSSD.cpp:456:25: error: reference to ‘DataType’ is ambiguous
return (type == DataType::kFLOAT && format == PluginFormat::kNCHW);
sampleUffSSD.cpp: In member function ‘virtual nvinfer1::IPluginV2* FlattenConcat::clone() const’:
sampleUffSSD.cpp:467:110: error: invalid new-expression of abstract class type ‘FlattenConcat’
return new FlattenConcat(mFlattenedInputSize.data(), mFlattenedInputSize.size(), mFlattenedOutputSize);
sampleUffSSD.cpp:289:7: note: because the following virtual functions are pure within ‘FlattenConcat’:
class FlattenConcat : public IPluginV2
/usr/include/aarch64-linux-gnu/NvInfer.h:2750:18: note: virtual bool nvinfer1::IPluginV2::supportsFormat(nvinfer1::DataType, nvinfer1::PluginFormat) const
virtual bool supportsFormat(DataType type, PluginFormat format) const = 0;
sampleUffSSD.cpp: In member function ‘virtual nvinfer1::IPluginV2* FlattenConcatPluginCreator::createPlugin(const char*, const nvinfer1::PluginFieldCollection*)’:
sampleUffSSD.cpp:527:34: error: invalid new-expression of abstract class type ‘FlattenConcat’
return new FlattenConcat();
sampleUffSSD.cpp: In member function ‘virtual nvinfer1::IPluginV2* FlattenConcatPluginCreator::deserializePlugin(const char*, const void*, size_t)’:
sampleUffSSD.cpp:533:58: error: invalid new-expression of abstract class type ‘FlattenConcat’
return new FlattenConcat(serialData, serialLength);
wctype
…/Makefile.config:159: recipe for target ‘…/…/bin/chobj/sampleUffSSD.o’ failed
make: *** […/…/bin/chobj/sampleUffSSD.o] Error 1
make: *** Waiting for unfinished jobs…
…/Makefile.config:166: recipe for target ‘…/…/bin/dchobj/sampleUffSSD.o’ failed
make: *** […/…/bin/dchobj/sampleUffSSD.o] Error 1
please help me what to do ?
