really simple (and useless in this form), but everytime i assign some value to blocchiC.elementi thread stops and i got error from the host’s clEnqueueReadBuffer function.
If i try blocchiC=blocchiA it works fine and the output is correct.
What i can do to manipulate every single element of blocchiA, B and C?
Last thing, if i do something like “float foo = blocchiC[iGID].elementi[0][0];” i got no error but i didn’t verified the value of that foo.
I don’t think it’s a struct issue, I think it’s more that OpenCL doesn’t support the use of double pointers (2D arrays). You can use 2D images, but I know for sure you can’t use a 2D buffer, or a struct that contains a 2D buffer.
thank you, i finally got it working with a single pointer :D
the odd thing is that it works only with driver 256, with other version i got some assembler error when building the program! i think i’m back to cuda :D
declares a pointer in private memory space to a pointer in private memory pointing to a private float (as this is the default). Should be something like
