Cannot use the USB 3.0 type A port on Auvidea J142 board with TX2i
Greetings, I’m facing a problem after successfully flashed jetson TX2i on the j142 carrier board the system boot up but I cannot use the USB 3.0 type A port. More detail like a command that I run with some log file is in the link below.
https://docs.google.com/document/d/16IY3etm2u3icGzaqIRHzvyyHFakUxkguZtZG3558yaw/edit?usp=sharing
Any advises about what that seem to be the problem and how to fix it ?
Thank you
  1. NV moderator can never know what is really happened on your custom board as we don’t have the correct schematic for the custom board.
  2. Please try to access the board by using uart console first. You could disable “quiet” in extlinux.conf to enable full log.
This is my uart console after disable quiet in extlinux.conf
bootconsole.txt (25.8 KB)
And USB 3.0 port type A port on J142 has no power (when I plugin CHARGER Doctor to measure J142 USB 3.0 type A port voltage and current nothing happen)
Thank you.
It looks like the format of your log is out of order and lots of info is missing. Totally not readable.
Could you resize your terminal and try to dump the correct format ?
