Cannot work Camera when simulation restart
I try to launch camera to subscribe an image from ROS 2.
I am using Python REPL to launch camera.
When the simulation was run again (“stop” button → “play” button), the camera image was not updated.
How can I solve it?
import math
import omni.kit.commands
import omni
from omni.isaac.core.utils import stage
from omni.isaac.core.utils.render_product import create_hydra_texture
import omni.kit.viewport.utility
from pxr import UsdGeom
import omni.graph.core as og
from omni.isaac.core.utils.prims import set_targets
from omni.kit.viewport.utility import get_viewport_from_window_name
Frame_per_Second = 60.0
image_height = 600
image_width = 600
aspect_ratio = float(image_width) / float(image_height)
horizontal_fov_rad = 1.3962634
horizontal_focal_length = 30
vertical_focal_length = 30
focus_distance = 400
horizontal_aperture = math.tan(horizontal_fov_rad / 2.0) * 2.0 * horizontal_focal_length
vertical_aperture = math.tan(horizontal_fov_rad / aspect_ratio / 2.0) * 2.0 * vertical_focal_length
camera_prim = UsdGeom.Camera(omni.usd.get_context().get_stage().DefinePrim("/World/Camera", "Camera"))
xform_api = UsdGeom.XformCommonAPI(camera_prim)
xform_api.SetTranslate(Gf.Vec3d(0, 0, 0))
xform_api.SetRotate((90, 0, -90), UsdGeom.XformCommonAPI.RotationOrderXYZ)
camera_prim.GetHorizontalApertureAttr().Set(horizontal_aperture)
camera_prim.GetVerticalApertureAttr().Set(vertical_aperture)
camera_prim.GetProjectionAttr().Set("perspective")
camera_prim.GetFocalLengthAttr().Set(horizontal_focal_length)
camera_prim.GetFocusDistanceAttr().Set(focus_distance)
camera_prim.GetClippingRangeAttr().Set((0.02, 300.0))
keys = og.Controller.Keys
(ros_camera_graph, _, _, _) = og.Controller.edit(
        "graph_path": prim_path + "/Camera_Graph",
        "evaluator_name": "push",
        "pipeline_stage": og.GraphPipelineStage.GRAPH_PIPELINE_STAGE_ONDEMAND,
        keys.CREATE_NODES: [
            ("OnTick", "omni.graph.action.OnTick"),
            ("createRenderProduct", "omni.isaac.core_nodes.IsaacCreateRenderProduct"),
            ("cameraHelperRgb", "omni.isaac.ros2_bridge.ROS2CameraHelper"),
            ("cameraHelperInfo", "omni.isaac.ros2_bridge.ROS2CameraHelper"),
        keys.CONNECT: [
            ("OnTick.outputs:tick", "createRenderProduct.inputs:execIn"),
            ("createRenderProduct.outputs:execOut", "cameraHelperRgb.inputs:execIn"),
            ("createRenderProduct.outputs:execOut", "cameraHelperInfo.inputs:execIn"),
            ("createRenderProduct.outputs:renderProductPath", "cameraHelperRgb.inputs:renderProductPath"),
            ("createRenderProduct.outputs:renderProductPath", "cameraHelperInfo.inputs:renderProductPath"),
        keys.SET_VALUES: [
            ("createRenderProduct.inputs:cameraPrim", prim_path + "/Camera"),
            ("createRenderProduct.inputs:enabled", True),
            ("createRenderProduct.inputs:height", image_height),
            ("createRenderProduct.inputs:width", image_width),
            ("cameraHelperRgb.inputs:frameId", child.attrib["name"]),
            ("cameraHelperRgb.inputs:topicName", prim_path + "/" + child.find("topic").text),
            ("cameraHelperRgb.inputs:type", "rgb"),
            ("cameraHelperInfo.inputs:frameId", child.attrib["name"]),
            ("cameraHelperInfo.inputs:topicName", prim_path + "/camera_info"),
            ("cameraHelperInfo.inputs:type", "camera_info"),
Please save above to test.py, and you can launch by following command.
(sleep 1; cat test.py; sleep 20) | telnet localhost 8223
Please enable extentions, omni.isaac.ros2_bridge and omni.isaac.repl before launching above command.
The viewport is launched by above command, but the viewport resolution is not changed.
I solved with following code.
import math
import omni
image_height = 600
image_width = 600
        "evaluator_name": "execution",
        keys.CONNECT: [
        keys.SET_VALUES: [
