Cannot write image to Jetson Orin Nano
I used to write image to Orin Nano board. But since yesterday, I couldn’t write image to successfully to SD card via both SDK manager and command.
From SDK manager, I got the error messages:
17:16:42 ERROR: Flash Jetson Linux - flash: [ 0.3183 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
17:16:42 INFO: Flash Jetson Linux - flash: [ 0.3354 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
17:16:42 INFO: Flash Jetson Linux - flash: [ 0.3404 ] Assuming zero filled SBK key
17:16:42 INFO: Flash Jetson Linux - flash: [ 0.3539 ] MB1-BCT version: 0.10
17:16:42 ERROR: Flash Jetson Linux - flash: [ 0.3589 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
17:16:42 ERROR: Flash Jetson Linux - flash: [ 0.3595 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
17:16:42 INFO: Flash Jetson Linux - flash: [ 0.3771 ] adding BCH for mb1_bct_MB1_aligned.bct
17:16:42 INFO: Flash Jetson Linux - flash: [ 0.3821 ] Assuming zero filled SBK key
17:16:42 INFO: Flash Jetson Linux - flash: [ 0.4246 ] BR_CID: 0x80012344705DE7870400000003000280
17:16:42 INFO: Flash Jetson Linux - flash: [ 0.5516 ] Sending bct_br
17:16:47 ERROR: Flash Jetson Linux - flash: [ 0.6787 ] ERROR: might be timeout in USB write.
17:16:47 INFO: Flash Jetson Linux - flash: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
17:16:47 ERROR: Flash Jetson Linux - flash: command terminated with error
17:16:47 SUMMARY: DateTime Target Setup - target: Depends on failed component
Also, I exported the debug log from SDK manager:
SDKM_logs_2023-07-14_17-12-20.zip (380.8 KB)
Can anyone help me with this?
please try these commands on your host PC:
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
Or maybe try with a different USB cable/USB port, or different host (Ubuntu 18.04 should be more stable than 20.04).
It’s a known issue on Orin series devices, but we still have not worked out an universal solution to it.
Thanks for replying.
I’ve tried Docker container and virtual machine of Ubuntu 18.04 on the same host as before, and neither of them works. Then, I changed the host to another running Ubuntu 18.04. It works.
Hope you guys will find a universal solution on this soon.
