Description
I am creating a virtual environment in python. I can’t access TensorRT when the venv is activated.
Environment
TensorRT Version: 7.1.3.0
GPU Type: Xavier AGX
Nvidia Driver Version:
CUDA Version: 10.2
CUDNN Version: 8.0
Operating System + Version: L4T R32.5.0
Python Version (if applicable): 3.6.9
Steps To Reproduce
Using:
$ python3
>>> import tensorrt as rt
>>> print (rt.__version__)
I get 7.1.3.0 as output.
I then create a virtual environment using:
$ python3.6 -m venv myenv
I activate the environment and then try to import TensorRT. I get a Module not found error.
Is there a simple way I could use TensorRT from inside the venv?
NVES
2
This looks like a Jetson issue. Please refer to the below samples in case useful.
For any further assistance, we will move this post to to Jetson related forum.
This is what I’ve tried:
$ export LD_LIBRARY_PATH=/usr/lib/python3.6/dist-packages/tensorrt:$LD_LIBRARY_PATH
but it didn’t work, I still get the error.
We recommend you to create virtual environment with --system-site-packages
Hope following similar posts may help you.
system
Closed
6
