I can receive a coredump occasionally when a program runs for a long time.
#0 0x00040000004a4c54 in ?? ()
I focus on the address [0x00040000004a4c54], remove the High 32-bit,then the address is [0x00000000004a4c54]. This is very important.
I have found the source code.
// Protocol Buffers - Google's data interchange format
// Copyright 2008 Google Inc. All rights reserved.
// https://developers.google.com/protocol-buffers/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions are
// met:
// * Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// * Redistributions in binary form must reproduce the above
// copyright notice, this list of conditions and the following disclaimer
// in the documentation and/or other materials provided with the
// distribution.
// * Neither the name of Google Inc. nor the names of its
// contributors may be used to endorse or promote products derived from
// this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
This file has been truncated. show original
View assembly & souce code.
I use gdb to debug and trace it. single step in
(gdb) p/x $x17
$1 = 0x4a4c54
(gdb) x/4wx 0x00040000004a4c54
0x40000004a4c54 Cannot access memory at address 0x40000004a4c54
the program can produce a coredump occasionally when execute the instruct ‘br x17’.
I doubt that the cause of this problem is a bug of the CPU.
Please help me handle it !!!
Hi @nicklgw . This is the Omniverse forums. What NVIDIA product is this topic related to?
The platform we used is TX2
Hi @nicklgw
This topic belongs in the Jetson forums. I have moved it over for you.
Tom
For information, do you use Jetpack 4.6.3? This is the latest release for TX2 series.
The OS distribution version we used is the ubuntu16.04.
Linux tegra-ubuntu 4.4.38-rt49-tegra #1 SMP PREEMPT RT Fri Jul 23 10:50:43 CST 2021 aarch64 aarch64 aarch64 GNU/Linux
R28.2.1
You are using Jetpack 3 release. We would suggest upgrade to latest Jetpack 4.6.3 and give it a try.
Have you ever had a similar problem before?
No, we don’t observe similar issue. Since Jetpack 3 releases are released for a while, it would be better if you can upgrade. Or may try latest Jetpack 3 version r28.5
system
Closed
June 14, 2023, 2:15am
12
