Hi all!
I wrote a programm which is using cuda. If there is an cuda device on the system, the programm take the cuda algorithm otherwise it take the CPU-Solution.
Now, I want test the programm on a system which has no cuda device. But, I can’t build it? What is the problem? The project includes the toolkit. But, is it required to install the cuda-driver only for the build process?
A simple yes or no is enough.
best regards
