Can't capture Frame "glDisable(cap = 0x00009346)"
I am running NSight 5.4 on Win7x64 with VS2017.
My graphics card is GTX1060.
The app I want to debug runs with OpenGL 4.3.
Whenever I try to capture a frame I get an error that NSight is unable to capture with
Reason: glDisable(cap = 0x00009346)
I think cap = 0x00009346 is GL_CONSERVATIVE_RASTERIZATION_NV but I am not 100% sure.
So how can I be able to capture frames with this setup?
Thank you for your help.
I’m sorry Nsight 5.4 doesn’t support the function glDisable(), please refer to the document for Supported OpenGL Functions http://docs.nvidia.com/nsight-visual-studio-edition/5.4/Nsight_Visual_Studio_Edition_User_Guide.htm#Graphics_OGL_Functions.htm%3FTocPath%3DGraphics%20Debugger|Frame%20Debugging|OpenGL|_____12
Maybe you can use other functions instead of glDisable().
Regards,
Letitia
Thanks for your answer.
Are you sure glDisable() is not supported ?
glDisable() is normally used quite extensively for various GL capabilities like GL_SCISSOR_TEST, GL_DEPTH_TEST, GL_ALPHA_TEST etc.
I’d rather guess GL_CONSERVATIVE RASTERIZATION_NV is not supported by nsight yet.
