I’m using a planar force field but I can’t set correctly the plane normal. Independently from the values I set the object always move in the same way. I attach a video recording to better explain the problem I’m facing.
Hi Federico,
Yes, this is a bug that has been fixed in the newest version of the Force Fields extension.
I’m trying to get it into the next release.
Rick
