I tried compiling the samples on an x86_64 machine and it throws an error I don’t understand:
nvcc -o obj/release/dxtc.cu_o -c dxtc.cu -m64 -I. -I/usr/local/cuda_libs/cuda64/include -I…/…/common/inc -DUNIX -O3
Internal error: check_target_config: target wchar_t is too large
Any ideas or workarounds?
Note: I added -m64 in the makefile, needed because nvcc assumes 32 bits.
EDIT: After switching to the RHEL5 runtime, it now works (I was using SUSE 10.2). I’m on kubuntu feisty btw.
For what it is worth, I have compiled the examples on a 64bit OpenSuse 10.2 machine and did not encounter any problems… I had to install a few development items beyond the standard OpenSuse install but nothing I thought was unusual.
