Hello, I installed JetPack SDK 4.6.1 on SSD using NVIDIA SDK Manager.
I cant configure the CSI Connector with sudo /opt/nvidia/jetson-io/jetson-io.py
. Window appears and closes fastly.
I use JetPack SDK 4.6.1 which works fine, built on Jetson Xavier NX Developer Kit with NVIDIA SDK Manager 1.7.3 (last version). Thanks
There’s no problem for this version to run the jetson-io
Could you reflash it to try again.
