Can't connect more than two usb2.0 camera on orin agx
Hi
Currently im trying to enable four usb 2.0 cameras with 320 * 240 * 30hz (mjpeg) on a Jetosn Orin AGX 64gb.
The total bandwith is definitely below 480mbps,even the raw image bandwidth is 320 *240 *30 /1024/1024*4=26.36MB, unconsidering the image is encoded as mjpeg
When I connect more than 2 cameras, I got error on kernel log: No enough bandwidth for new device state.
I dont thinks its an matter with bandwidth, any other reason may cause this issue?
If you use AGX Orin developer kit, we would suggest shift the camera to the type-C port, as suggested:
USB Port bandwidth limitation - #8 by DaneLLL
If a USB2 device is connected, the total bandwidth is only 480Mbps. Here is a related topic:
What is total USB bandwith of the 4 USB ports? - #3 by DaneLLL
I have to use four usb2.0 camera , which are with a very low resolution.
Just wanna ask if there are other cases, that multi usb cameras are somehow not well supported on orin platform
We also tried to load 4 usb2.0 camera on a 1to4 usb3 hub, connect to agx orin on typec port, and can only maxiumly connect 2 camera.
Although caneras are mounted on 480Mb roothub, but bandwidth is enough.
Only two hubs (one Type-C, one USB) with each connecting two cameras can simultaneously enable four cameras.
@DaneLLL
