Also source_sync.sh does not work and outputs this: Cloning into ‘/some/directory/here/Linux_for_Tegra/sources/hardware/nvidia/soc/tegra’… fatal: unable to connect to nv-tegra.nvidia.com: nv-tegra.nvidia.com[0: 35.82.181.43]: errno=Connection refused nv-tegra.nvidia.com[1: 34.216.216.36]: errno=Connection refused
A camera device that we purchased requires Jetpack 4.2.1 for TX2. We have the TX2 dev kit, and apparently Jetpack 4.2.1 is listed to be available through SDKmanager if the option for archived versions is enabled, but when SDKmanager tries to download it, it simply fails repeatedly. Is this the same issue ?
Downloading default kernel/nvgpu source…
Cloning into ‘/home/lab/Downloads/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/kernel/nvgpu’…
fatal: unable to connect to nv-tegra.nvidia.com: nv-tegra.nvidia.com[0: 34.216.216.36]: errno=Connection timed out nv-tegra.nvidia.com[1: 35.82.181.43]: errno=Connection timed out
