Can't convert model.pb by TF-TRT
Hello.
OS : Ubuntu18.04
python : 3.6.8
tensorflow-gpu : 1.13.1
GPU : TITAN RTX * 2
I built model.pb file by tf.saved_model.builder.SavedModelBuilder.
And I tried to convert this pb-file by the following command.
graph = tf.Graph()
config = tf.ConfigProto()
config.gpu_options.allow_growth = True
config.allow_soft_placement = True
with graph.as_default():
    with tf.Session(config=config) as sess:
        # Create a TensorRT inference graph from a SavedModel:
        trt_graph = trt.create_inference_graph(
            input_graph_def=None,
            outputs=['outputs'],
            input_saved_model_dir='saved_model/1',
            output_saved_model_dir='saved_model/1_trt',
            input_saved_model_tags=['serve'],
            max_batch_size=1,
            max_workspace_size_bytes=100,
            minimum_segment_size=3,
            precision_mode='fp16',
            is_dynamic_op=True,
            maximum_cached_engines=1,
            cached_engine_batch_sizes=None,
            use_calibration=True,
            session_config=config)
But I couldn’t convert and received the following message.
W tensorflow/contrib/tensorrt/segment/segment.cc:683] Segment 0 has multiple devices attached: /device:CPU:0, /device:GPU:0, /job:localhost/replica:0/task:0/device:GPU:0,  choosing /device:CPU:0
W tensorflow/contrib/tensorrt/segment/segment.cc:683] Segment 1 has multiple devices attached: /device:CPU:0, /device:GPU:0,  choosing /device:CPU:0
W tensorflow/contrib/tensorrt/segment/segment.cc:683] Segment 2 has multiple devices attached: /device:CPU:0, /device:GPU:0,  choosing /device:CPU:0
W tensorflow/contrib/tensorrt/segment/segment.cc:683] Segment 3 has multiple devices attached: /device:CPU:0, /device:GPU:0,  choosing /device:CPU:0
W tensorflow/contrib/tensorrt/segment/segment.cc:683] Segment 4 has multiple devices attached: /device:CPU:0, /device:GPU:0,  choosing /device:CPU:0
W tensorflow/contrib/tensorrt/segment/segment.cc:683] Segment 10 has multiple devices attached: /device:CPU:0, /device:GPU:0,  choosing /device:CPU:0
W tensorflow/contrib/tensorrt/segment/segment.cc:683] Segment 11 has multiple devices attached: /device:CPU:0, /device:GPU:0,  choosing /device:CPU:0
W tensorflow/contrib/tensorrt/segment/segment.cc:683] Segment 25 has multiple devices attached: /device:CPU:0, /device:GPU:0,  choosing /device:CPU:0
I tensorflow/contrib/tensorrt/convert/convert_graph.cc:913] Number of TensorRT candidate segments: 26
W tensorflow/contrib/tensorrt/convert/convert_graph.cc:454] Detected multiple(2) devices for the segment. Picking first one to continue but this shouldn't have happened
What does this mean?
Please help.
The following message is just a warning saying that different ops in a TRT segment have different devices assigned to them. You can ignore this usually.
Why do you think that it couldn’t convert the graph? Have you checked the resulted graph trt_graph?
