Can't create MetadataContainer
The source capture video to screen refered by 09_camera_jpeg_capture.
And It works fine.
Then we add meta data part to it.
iCameraProvider->supportsExtension(Argus::EXT_BAYER_SHARPNESS_MAP) true.
iEglStreamSettings->setMetadataEnable(true);
iBayerSharpnessMapSettings->setBayerSharpnessMapEnable(true);
NvEglRenderer *renderer = NvEglRenderer::createEglRenderer(“renderer0”,PREVIEW_SIZE.width(), PREVIEW_SIZE.height(), 0, 0);
UniqueObjEGLStream::MetadataContainer metadataContainer(EGLStream::MetadataContainer::create(m_renderer->getEGLDisplay(), m_stream));
metadataContainer is NULL.
What are we missing?
PS: Where is the class reference for EGLStream?
Thanks for your help!!
EGLStream::MetadataContainer is demonstrated in the samples:
/usr/src/jetson_multimedia_api/argus/samples/histogram
/usr/src/jetson_multimedia_api/argus/samples/bayerAverageMap
Be default the samples should be run without issues. You may refer to them for developing your usecase.
The issue resolved.
In our code, m_stream should be cast to IEGLStream.
A related question:
The calculation of sharpness for bayer data is run in ISP or CPU?
Thank you!
Would like to confirm if the question is for the header file:
jetson_multimedia_api/argus/include/Argus/Ext/BayerSharpnessMap.h
