Can't do apt update: public key is not available: NO_PUBKEY 1A2E4274AC7A8482
Doing a simple
apt update
I get:
W: GPG error: file:/var/libopencv4tegra-repo  Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1A2E4274AC7A8482
E: The repository 'file:/var/libopencv4tegra-repo  Release' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
Any ideas on this? I searched but I didn’t see anyone else havnig that problem. It looks like if I could find the key server for that I could import the key but I can’t.
Any suggestions welcome…
Hi MLLearner,
How do you hit this error? Does it happen when using Jetpack??
Just checked, this should be a warning message and not cause further error.
This is mentioned in release note.
