Can't enable esw_multiport on BlueField-2
I’m trying to enable multiport eSwitch (esw_multiport) on my BlueField-2 DPU.
I did the following:
mlxconfig -d /dev/mst/mt41686_pciconf0 -y s LAG_RESOURCE_ALLOCATION=1
reboot
devlink dev param set pci/0000:03:00.0 name esw_multiport value true cmode runtime
But I get this error:
kernel answers: Operation not supported
Does anyone know if I need to use another parameter, or if there’s another step after reboot to make it work?
Can you first make sure you are running the latest BFB image version (bf-bundle-3.1.0-76_25.07_ubuntu-22.04_prod.bfb)
https://developer.nvidia.com/doca-downloads?deployment_platform=BlueField&deployment_package=BF-Bundle&Distribution=Ubuntu&version=22.04&installer_type=BFB
BlueField SW bundle supporting BlueField-3 & BlueField-2, including DOCA 3.1.0, DPU-OS Ubuntu 22.04, BSP 4.12.0.13720, NIC-FW BF2 24.46.1006, BF3 32.46.1006, BF3 BMC-FW 25.07, BF3 BMC-eROT 00.02.0195.0000, BF2 BMC-FW 25.07, BF2 BMC-eROT 04.0f
Once the parameter is in place, make sure to cold boot the server (power cycle).
(There is not other parameters via mlxconfig to enable this feature).
