Hi. So I own a GTX 1650 and have 3 monitors connected, one via Displayport to HDMI converter-cable, and the other two via DVI and HDMI ports.
Before my GTX 770 failed I would only have to change the Xinerama-value in the X-configuration file to “1”, but if I do this, and reboot, the desktop (XFCE) boots up as usual, meaning windows dont maximise to span all monitors (which indicates nothing has changed) and games dont detect the 5760 width that should be enabled, and I cant set a ultra wide resolution.
Here is my config file, which used to live in /etc/X11/xorg.conf but I changed its location hoping it would work:
cat /etc/X11/xorg.conf.d/20-nvidia.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 470.63.01
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "1"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Samsung S24B300"
HorizSync 30.0 - 81.0
VertRefresh 56.0 - 75.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce GTX 1650"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-3"
Option "metamodes" "DVI-D-0: nvidia-auto-select +0+0, HDMI-0: nvidia-auto-select +3840+0, DP-1: nvidia-auto-select +1920+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
There is also a 00-keyboard file and that is it.
cat /etc/X11/xorg.conf.d/00-keyboard.conf
# Written by systemd-localed(8), read by systemd-localed and Xorg. It's
# probably wise not to edit this file manually. Use localectl(1) to
# instruct systemd-localed to update it.
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "se"
Option "XkbVariant" "dvorak"
EndSection
I would be very much appreciative of any assistance you may offer!
nvidia-bug-report.log.gz (96.3 KB)
