I’m installing Jetpack 3.3,
I installed OS,driver-CUDA-CUDNN via jetpack but when i am coming opencv installing step, such occurs occuring, normally its more longer error-fetch fails but giving brief version:
Err:6 Index of /ubuntu-ports xenial-security/universe arm64 libavcodec-dev arm64 7:2.8.14-0ubuntu0.16.04.1
403 Forbidden [IP: 91.189.88.150 80]
Err:8 Index of /ubuntu-ports xenial-security/universe arm64 libgme0 arm64 0.6.0-3ubuntu0.16.04.1
Get:10 Index of /ubuntu-ports xenial-security/universe arm64 libavformat-dev arm64 7:2.8.14-0ubuntu0.16.04.1 [889 kB]
Fetched 2107 kB in 6s (312 kB/s)
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/universe/x/xvidcore/libxvidcore4_1.3.4-1_arm64.deb 403 Forbidden [IP: 91.189.88.150 80]
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/universe/f/ffmpeg/libavcodec-dev_2.8.14-0ubuntu0.16.04.1_arm64.deb 403 Forbidden [IP: 91.189.88.150 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Because I installed everything for tensorrt-opencv-visionworks; I try to install via Build OpenCV on the NVIDIA Jetson TX2 - JetsonHacks
I did before many times from this link, it is so easy but it gives the same error.
What I tried:
Changing server from Software Updates
Changing sources.list file
A few solutions find from internet for failed to fetch error.
Any help would be appricated because I’m deeply stuck :(
