My deepStreamSDK is 4.0
Referring the example of faster rcnn, I create a custom layer as a plugin.
When running the deepstream pipeline, it says it can’t find the plugin.
nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:log(): getPluginCreator could not find plugin PLUGIN_NAME version 1 namespace
All the settings follows the example of faster rcnn, and NvDsInferPluginFactoryCaffeGet is called.
How can I print all the registered plugins and debug this?
Have you updated this parameter to your plugin library path:
custom-lib-path=nvdsinfer_custom_impl_fasterRCNN/libnvdsinfer_custom_impl_fasterRCNN.so
yes. I had updated the path to my own custom library.
by the way, I tried to use factoryLegacy and it works as expected.
In factoryLegacy, it implements NvDsInferPluginFactoryRuntimeGet which is called when model engine file is deserialized.
However, I can’t implement NvDsInferPluginFactoryRuntimeGet in IPluginFactoryV2, thus it can’t find the plugin when deserialization.
Do you have any idea about the deserialization part?
Could you share the source code and model of your implementation so we can check it for you?
kayccc
November 19, 2019, 6:41am
#5
Hi OnePieceOfDeepLearning,
We haven’t heard back from you in a couple weeks, so marking this issue resolved by “accepting” this comment as answer.
Please open a new forum issue when you are ready and we’ll pick it up there.
