I’m customizing some pins for a custom carrier board. Some of the customizations are related to the UPHY pins of the SEC 4 of 5. When I open the Jetson_AGX_Orin_Series_Pinmux_Config_Template_1.5.xlsm they seem to be there (for example, the pin H25 is at row 427 of the excel file). But when I generate the dtsi file, I cant find the node related to that pin (in this case nvhs0_tx0n). This happens with more of the UPHY pins. How can I customize them if they aren’t at the generated pinmux.dtsi?
You don’t need to configure the pinmux of the UPHY pin. Just follow the adaptation guide document.
