Can't flash basic ubuntu headless version on agx orin 64GB
I’m trying to build a custom rootfs (without gui) and flash it to the agx. I want to run agx as a headless unit because I dont need the extra GUI stuff.
I have done the following:
  1. Download L4T 35.4.1 BSP from the nvidia website. (https://developer.nvidia.com/downloads/embedded/l4t/r35_release_v4.1/release/jetson_linux_r35.4.1_aarch64.tbz2/)
  2. Run sudo ./nv_build_samplefs.sh --abi aarch64 --distro ubuntu --flavor basic --version focal
  3. Extract sample_fs to rootfs
  4. Run ./apply_binaries
  5. Run l4t_create_default_user.sh -u ubuntu -a to create a user
  6. Run ‘./nvsdkmanager_flash.sh --storage nvme0n1p1’
  7. The flash is successful.
However, how do I boot my agx with tty console (so i can setup ssh over wifi). There is no /dev/ttyACM*. (im using type-c next to 40pin for both flashing and debug console over tty)
dmesg logs:
[1028294.953983] EXT4-fs (loop28): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[1028301.093998] usb 1-4: USB disconnect, device number 51
[1028301.402892] usb 1-4: new high-speed USB device number 52 using xhci_hcd
[1028301.551941] usb 1-4: New USB device found, idVendor=0955, idProduct=7023, bcdDevice= 4.01
[1028301.551952] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[1028301.551956] usb 1-4: Product: APX
[1028301.551959] usb 1-4: Manufacturer: NVIDIA Corp.
[1028307.708470] loop28: detected capacity change from 0 to 131072
[1028321.038614] nfsd: last server has exited, flushing export cache
[1028322.175594] NFSD: Using UMH upcall client tracking operations.
[1028322.175600] NFSD: starting 90-second grace period (net f0000000)
[1028333.081975] usb 1-4: USB disconnect, device number 52
[1028351.834176] usb 1-4: new high-speed USB device number 53 using xhci_hcd
[1028351.983217] usb 1-4: New USB device found, idVendor=0955, idProduct=7035, bcdDevice= 0.01
[1028351.983220] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1028351.983221] usb 1-4: Product: Linux for Tegra
[1028351.983222] usb 1-4: Manufacturer: NVIDIA
[1028351.983222] usb 1-4: SerialNumber: 1420923017265
[1028351.988319] rndis_host 1-4:1.0 usb0: register 'rndis_host' at usb-0000:00:14.0-4, RNDIS device, 36:a1:b3:c7:dd:8b
[1028351.988567] usb-storage 1-4:1.2: USB Mass Storage device detected
[1028351.988806] scsi host8: usb-storage 1-4:1.2
[1028352.995604] scsi 8:0:0:0: Direct-Access     mmc0     0                     PQ: 0 ANSI: 2
[1028352.996334] scsi 8:0:0:1: Direct-Access     mmc0b0   0                     PQ: 0 ANSI: 2
[1028352.996969] scsi 8:0:0:2: Direct-Access     mmc0b1   0                     PQ: 0 ANSI: 2
[1028352.997580] scsi 8:0:0:3: Direct-Access     ext0     0                     PQ: 0 ANSI: 2
[1028352.997976] sd 8:0:0:0: Attached scsi generic sg0 type 0
[1028352.998453] sd 8:0:0:1: Attached scsi generic sg1 type 0
[1028352.998650] sd 8:0:0:0: Power-on or device reset occurred
[1028352.998824] sd 8:0:0:2: Attached scsi generic sg2 type 0
[1028352.999486] sd 8:0:0:3: Attached scsi generic sg3 type 0
[1028352.999595] sd 8:0:0:0: [sda] 124321792 512-byte logical blocks: (63.7 GB/59.3 GiB)
[1028353.000585] sd 8:0:0:1: Power-on or device reset occurred
[1028353.001562] sd 8:0:0:1: [sdb] Media removed, stopped polling
[1028353.002316] sd 8:0:0:2: Power-on or device reset occurred
[1028353.003011] sd 8:0:0:2: [sdc] Media removed, stopped polling
[1028353.003682] sd 8:0:0:3: Power-on or device reset occurred
[1028353.004375] sd 8:0:0:3: [sdd] 500118192 512-byte logical blocks: (256 GB/238 GiB)
[1028353.004861] sd 8:0:0:3: [sdd] Write Protect is off
[1028353.004871] sd 8:0:0:3: [sdd] Mode Sense: 0f 00 00 00
[1028353.005310] sd 8:0:0:3: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[1028353.005759] sd 8:0:0:0: [sda] Write Protect is off
[1028353.005769] sd 8:0:0:0: [sda] Mode Sense: 0f 00 00 00
[1028353.006245] sd 8:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[1028353.007473] sd 8:0:0:1: [sdb] Attached SCSI removable disk
[1028353.008128] sd 8:0:0:2: [sdc] Attached SCSI removable disk
[1028353.041800] GPT:Primary header thinks Alt. header is not at the end of the disk.
[1028353.041808] GPT:250069679 != 500118191
[1028353.041812] GPT:Alternate GPT header not at the end of the disk.
[1028353.041814] GPT:250069679 != 500118191
[1028353.041816] GPT: Use GNU Parted to correct GPT errors.
[1028353.041840]  sdd: sdd1 sdd2 sdd3 sdd4 sdd5 sdd6 sdd7 sdd8 sdd9 sdd10 sdd11 sdd12 sdd13 sdd14
[1028353.044982] sd 8:0:0:3: [sdd] Attached SCSI removable disk
[1028353.046734]  sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9 sda10 sda11 sda12 sda13 sda14 sda15
[1028353.049210] sd 8:0:0:0: [sda] Attached SCSI removable disk
[1028854.520890] usb 1-4: USB disconnect, device number 53
[1028854.521086] rndis_host 1-4:1.0 usb0: unregister 'rndis_host' usb-0000:00:14.0-4, RNDIS device
[1028854.612640] sd 8:0:0:0: [sda] Synchronizing SCSI cache
[1028854.612696] sd 8:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[1028854.788687] sd 8:0:0:3: [sdd] Synchronizing SCSI cache
[1028854.788723] sd 8:0:0:3: [sdd] Synchronize Cache(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
Hi raj28,
If you are using the devkit, you should use Micro-USB port on the devkit to access the debug console.
Please find more details in the following instruction.
NVIDIA Jetson Orin - Serial Console (ridgerun.com)
