On Nano production module, I fused the key by command:
sudo ./odmfuse.sh -c PKC -i 0x21 -p -k "${CRE_FOLDER}/secureboot_sign_key/rsa_priv.pem"
Then I can flash the firmware with following command:
sudo MACHINE=orbit-nano BOARDID=3448 FAB="400" BOARDSKU="0002" BOARDREV="b00" ./tegra210-flash-helper.sh -B 1048576 flash.xml.in tegra210-orbit-nano-rev3-imx482.dtb orbit-nano.cfg 0xA4000 "" boot.img uwcam-image.ext4 -u ${CRE_FOLDER}/secureboot_sign_key/rsa_priv.pem
Everything works fine. I have done many boards with this command without problem.
Today I fused another Nano production module with extra options to turn off the JTAG and fixed the boot source to eMMC only, then the command is:
./odmfuse.sh -c PKC -i 0x21 -p --disable-jtag -r 0x08 -k "${CRE_FOLDER}/secureboot_sign_key/rsa_priv.pem"
The odmfuse.sh command returns success.
Then I come with the command to flash firmware above (exactly the same firmware file, same command). But the flashing hangs at following, only able to quit if CTRL+c or reboot the board or power off.
[ 0.1240 ]
[ 0.1240 ] Boot Rom communication
[ 0.1248 ] tegrarcm --chip 0x21 0 --rcm rcm_1_signed.rcm
[ 0.1254 ] BootRom is not running
[ 0.1719 ]
[ 0.1719 ] Sending BCTs
[ 0.1728 ] tegrarcm --download bct orbit-nano.bct
Compare with the fused but working board, I think that the bootrom of NOT working board was never run after I burnt its FUSE.
On another compare, I run the fuse command again:
On working board:
*** Calculating HASH from keyfile /work/works/uwcam/code/credencitals/secureboot_sign_key/rsa_priv.pem ... done
PKC HASH:
*** Generating fuse configuration ... done.
*** Start fusing ...
./tegraflash.py --chip 0x21 --applet nvtboot_recovery.bin --cmd "blowfuses odmfuse_pkc.xml;"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0017 ] Parsing fuse info as per xml file
[ 0.0027 ] tegraparser --fuse_info odmfuse_pkc.xml blow_fuse_data.bin
[ 0.0035 ]
[ 0.0036 ] Generating RCM messages
[ 0.0047 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0056 ] RCM 0 is saved as rcm_0.rcm
[ 0.0060 ] RCM 1 is saved as rcm_1.rcm
[ 0.0061 ] List of rcm files are saved in rcm_list.xml
[ 0.0061 ]
[ 0.0061 ] Signing RCM messages
[ 0.0069 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0075 ] Assuming zero filled SBK key
[ 0.0116 ]
[ 0.0116 ] Copying signature to RCM mesages
[ 0.0127 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0146 ]
[ 0.0146 ] Boot Rom communication
[ 0.0157 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.0174 ] BR_CID: 0x621010016446080218000000100682c0
[ 0.0185 ] RCM version 0X13
[ 0.0316 ] Boot Rom communication failed
[ 0.0317 ]
Error: Return value 3
Command tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
failed.
On not working board:
PKC HASH:
version 1.0.0
[ 0.0016 ] Parsing fuse info as per xml file
[ 0.0026 ] tegraparser --fuse_info odmfuse_pkc.xml blow_fuse_data.bin
[ 0.0034 ]
[ 0.0035 ] Generating RCM messages
[ 0.0041 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0047 ] RCM 0 is saved as rcm_0.rcm
[ 0.0050 ] RCM 1 is saved as rcm_1.rcm
[ 0.0051 ] List of rcm files are saved in rcm_list.xml
[ 0.0051 ]
[ 0.0051 ] Signing RCM messages
[ 0.0061 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0071 ] Assuming zero filled SBK key
[ 0.0112 ]
[ 0.0112 ] Copying signature to RCM mesages
[ 0.0122 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0139 ]
[ 0.0139 ] Boot Rom communication
[ 0.0148 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.0156 ] BootRom is not running
[ 0.0581 ]
[ 0.0582 ] Blowing fuses
[ 0.0606 ] tegrarcm --oem blowfuses blow_fuse_data.bin
#### CTRL + C here
[ 0.0626 ] Applet is not running on device. Continue with Bootloader
[ 4.7888 ]
Error: Return value 8
Command tegrarcm --oem blowfuses blow_fuse_data.bin
failed.
Is that correct that I broke the board by adding “–disable-jtag” or “-r 0x08” or both? I don’t think these options cause the broken, but they are the only different I changed in Fusing command.
Is there any ways what I can flash firmware on above not working board?
Any idea of what happened are welcome. Thank you.
