Can't flash Jetpack 6 on Orin Nano 4GB
I’m trying to flash Jetpack 6 DP on a Orin Nano 4GB with the A603 Seeed board. I’m using SDK Manager but it fails with the following error:
17:12:58 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
17:12:59 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
17:13:00 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
17:13:01 INFO: Flash Jetson Linux - flash: Cleaning up...
17:13:01 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
17:13:01 ERROR: Flash Jetson Linux - flash: command terminated with error
17:13:01 SUMMARY: DateTime Target Setup - target: Depends on failed component
I booted it in recovery mode, and it initially starts fine. I also disabled auto-suspend and rebooted my computer (Ubuntu 20.04):
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
The weird thing is that flashing Jetpack 5.1.3 works fine! Are there any ways to upgrade from Jetpack 5.1.3 to Jetpack 6?
Here are the logs (386.7 KB).
Please wait for the vendor to support this carrier board with JetPack 6.
The default BSP downloaded with SDK Manager definitely does not work here.
