Can't flash Jetpack 6 on Orin NX (A204 carrier board) using SDK Manager
Hi, we are having issues flashing JP6 on Orin NX (A204 carrier board) using SDK Manager.
Have tried disabling firewall, changing USB cable and other methods suggested on forums. Please see attached logs.
orinnx_jp6_failedflash.log (852.2 KB)
Your log is not even readable… Only a bunch of garbled characters.
Anyway, we don’t know what this A204 is, and you should ask the board vendor for help.
SDK Manager only works with DevKits.
I tried again with a DevKit, here is my error log. Failed with error ‘device is in invalid state’. I confirmed via lsusb that it was active and detected in recovery mode before and after flashing.
SDKM_logs_JetPack_6.0_(rev._1)_Linux_for_Jetson_Orin_NX_modules_2024-05-24_09-36-17.zip (338.9 KB)
Timeout
Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
Cleaning up…
Get the log.
Please find here serial log + another sdkm log
cutecom.log (132.7 KB)
SDKM_logs_JetPack_6.0_(rev._1)_Linux_for_Jetson_Orin_NX_modules_2024-05-24_12-01-27.zip (340.0 KB)
\cb6 E> I2C: slave not found in slaves.
\cb3 E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
\cb6 E> I2C_DEV: Failed to send register address 0x00000000.
\cb3 E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
\cb6 E> eeprom: Retry to read I2C slave device.
\cb3 E> I2C: slave not found in slaves.
\cb6 E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
\cb3 E> I2C_DEV: Failed to send register address 0x00000000.
\cb6 E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
\cb3 E> eeprom: Failed to read I2C slave device
\cb6 C> Task 0x0 failed (err: 0x1f1e050d)
\cb3 E> Top caller module: I2C_DEV, error module: I2C, reason: 0x0d, aux_info: 0x05
\cb6 I> Busy Spin\
I don’t believe you will get this on a DevKit; it should only happen on a custom board.
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/HR/JetsonModuleAdaptationAndBringUp/JetsonOrinNxNanoSeries.html#eeprom-modifications
