I want to install netcdf-4.4.1 to my computer, and I just followed the method introduced at this site.https://www.pgroup.com/resources/netcdf/netcdf43_pgi2014.htm#VERSIONBut the version of netcdf I am installing is not same as the site’s. So, I am faced with the problem.
The problem is about “cmake”.For the latest version of netcdf, after installing the zlib and hdf5, it’s needed to generate a makefile of netcdf with “cmake” instruction. When I run the cmake instruction, the shell show the message like this:
-- HDF5: Using hdf5 compiler wrapper to determine C configuration -- Found HDF5 libraries version 1.10.4 -- Found libdl: /usr/lib/x86_64-linux-gnu/libdl.so -- Found Math library: /usr/lib/x86_64-linux-gnu/libm.so -- Found bash: /usr/bin/bash Configuration Summary: -- Building Shared Libraries: ON -- Building netCDF-4: ON -- Building DAP Support: ON -- Building Utilities: ON Tests Enabled: ON -- DAP Remote Tests: ON -- DAP AUTH Tests: OFF -- Extra Tests: OFF -- Coverage Tests: OFF -- Parallel Tests: OFF -- Large File Tests: OFF Compiler: -- Build Type: DEBUG -- CMAKE_C_COMPILER: /usr/bin/cc -- CMAKE_C_FLAGS: -- CMAKE_C_FLAGS_DEBUG: -g -Wall -Wconversion -- Linking against: /usr/lib/x86_64-linux-gnu/hdf5/serial/libhdf5_hl.so;/usr/lib/x86_64-linux-gnu/hdf5/serial/libhdf5.so;/usr/lib/x86_64-linux-gnu/libpthread.so;/usr/lib/x86_64-linux-gnu/libsz.so;/usr/lib/x86_64-linux-gnu/libz.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libm.so;/usr/lib/x86_64-linux-gnu/libcurl.so # NetCDF C Configuration Summary ============================== # General ------- NetCDF Version: 4.4.1 Configured On: 2021年 04月 01日 星期四 16:25:24 WITA Host System: x86_64-Linux-5.8.0-48-generic Build Directory: /home/xuan/Desktop/WORK_DIR/netCDF/netcdf-4.4.1 Install Prefix: /usr/local # Compiling Options ----------------- C Compiler: /usr/bin/cc CFLAGS: -g -Wall -Wconversion CPPFLAGS: LDFLAGS: -Wl,--no-undefined AM_CFLAGS: AM_CPPFLAGS: AM_LDFLAGS: Shared Library: yes Static Library: no Extra libraries: -lhdf5_hl -lhdf5 -lpthread -lsz -lz -ldl -lm -lcurl # Features -------- NetCDF-2 API: yes HDF4 Support: no NetCDF-4 API: yes NC-4 Parallel Support: no PNetCDF Support: no DAP Support: yes Diskless Support: yes MMap Support: no JNA Support: no -- Configuring done CMake Error at CMakeLists.txt:1336 (ADD_EXECUTABLE): Cannot find source file: tst_fill_attr_vanish.c Tried extensions .c .C .c++ .cc .cpp .cxx .cu .m .M .mm .h .hh .h++ .hm .hpp .hxx .in .txx Call Stack (most recent call first): nc_test4/CMakeLists.txt:68 (add_bin_test) CMake Error at CMakeLists.txt:1336 (ADD_EXECUTABLE): No SOURCES given to target: nc_test4_tst_fill_attr_vanish Call Stack (most recent call first): nc_test4/CMakeLists.txt:68 (add_bin_test) CMake Generate step failed. Build files cannot be regenerated correctly..
What’s wrong for this situation?
