hello Nvidia Community
I am stuck with this issue since days.
I have tried different driver versions like 550, 535, 570.
But always nvidia-smi returns :
No devices found.
My Setup:
Baseboard is: HPE ProLiant DL385 Gen11
With 2 Teslas L40s.
I disabled nuveo default driver.
I downloaded the driver repository from your page for
wget https://de.download.nvidia.com/tesla/535.104.12/nvidia-driver-local-repo-ubuntu2204-535.104.12_1.0-1_amd64.deb
wget https://us.download.nvidia.com/tesla/570.86.15/nvidia-driver-local-repo-ubuntu2404-570.86.15_1.0-1_amd64.deb
(and also for 550)
I ll installed them. But after the installation finished I have always the same result:
Nvidia smi error
nvidia-smi
No devices were found
lsmod output
lsmod | grep nvidia
nvidia_uvm 2088960 0
nvidia_drm 131072 0
nvidia_modeset 1544192 1 nvidia_drm
nvidia 89821184 2 nvidia_uvm,nvidia_modeset
video 73728 1 nvidia_modeset
lspci output
lspci | grep -i nvidia
82:00.0 3D controller: NVIDIA Corporation AD102GL [L40S] (rev a1)
e3:00.0 3D controller: NVIDIA Corporation AD102GL [L40S] (rev a1)
dmesg output
sudo dmesg | grep -i nvidia
[ 12.329658] nvidia: loading out-of-tree module taints kernel.
[ 12.329669] nvidia: module license 'NVIDIA' taints kernel.
[ 12.329674] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 12.329676] nvidia: module license taints kernel.
[ 12.425566] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 12.426989] nvidia 0000:e3:00.0: enabling device (0140 -> 0142)
[ 12.427097] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 12.427100] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 12.427102] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 12.427103] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 12.427105] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 12.468132] nvidia 0000:82:00.0: enabling device (0140 -> 0142)
[ 12.468221] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 12.468224] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 12.468226] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 12.468227] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 12.468229] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 12.512085] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 570.86.15 Thu Jan 23 23:23:10 UTC 2025
[ 12.525639] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 570.86.15 Thu Jan 23 22:30:06 UTC 2025
[ 12.528385] [drm] [nvidia-drm] [GPU ID 0x0000e300] Loading driver
[ 13.738225] caller os_map_kernel_space+0x120/0x130 [nvidia] mapping multiple BARs
[ 13.747400] [drm:nv_drm_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x0000e300] Failed to allocate NvKmsKapiDevice
[ 13.747939] [drm:nv_drm_register_drm_device [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x0000e300] Failed to register device
[ 13.758102] [drm] [nvidia-drm] [GPU ID 0x00008200] Loading driver
[ 15.043365] caller os_map_kernel_space+0x120/0x130 [nvidia] mapping multiple BARs
[ 15.052730] [drm:nv_drm_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00008200] Failed to allocate NvKmsKapiDevice
[ 15.055210] [drm:nv_drm_register_drm_device [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00008200] Failed to register device
[ 83.251117] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 83.275140] nvidia-uvm: Loaded the UVM driver, major device number 509.
modinfo nvidia
filename: /lib/modules/6.8.0-52-generic/updates/dkms/nvidia.ko.zst
alias: char-major-195-*
version: 550.127.08
supported: external
license: NVIDIA
firmware: nvidia/550.127.08/gsp_tu10x.bin
firmware: nvidia/550.127.08/gsp_ga10x.bin
srcversion: 647D5D7BEC2EB194BCD0BDF
alias: pci:v000010DEd*sv*sd*bc06sc80i00*
alias: pci:v000010DEd*sv*sd*bc03sc02i00*
alias: pci:v000010DEd*sv*sd*bc03sc00i00*
depends:
retpoline: Y
vermagic: 6.8.0-52-generic SMP preempt mod_unload modversions
sig_id: PKCS#7
signer: an-ai Secure Boot Module Signature key
sig_key: 20:72:3E:68:61:23:6E:C3:D6:5A:B8:83:8D:E5:33:85:7B:8B:01:D1
sig_hashalgo: sha512
signature: 15:3E:84:A1:EF:09:23:E7:AB:A3:BB:3E:1B:18:08:47:77:6E:42:87:
EB:09:11:D2:AE:EC:8F:9F:0C:9E:77:64:07:D2:33:7A:51:5C:88:21:
F7:96:3A:F6:72:3C:18:3D:B4:0F:CE:34:A3:86:56:7E:23:89:DB:C4:
E8:75:51:A5:CF:24:EF:D4:42:2B:F4:87:41:14:9E:68:99:06:2C:02:
64:B8:E9:18:1D:D7:13:61:8D:6D:CA:03:24:F1:73:50:7C:4A:D8:66:
1A:DF:FD:C4:89:A4:3B:B2:7B:73:E5:7B:DB:5A:5B:A6:21:72:B7:08:
9B:05:6E:DA:F2:36:3E:08:B5:D6:AA:4B:C7:E7:B9:03:61:B7:B9:14:
F6:2B:72:14:D3:B1:B1:51:73:CC:D3:7E:8E:A7:DE:7B:2A:A9:10:65:
97:E3:1E:41:37:17:D9:18:2B:07:C6:11:05:B5:D9:25:A0:DF:23:A2:
1A:23:B4:9C:80:A5:78:8A:5A:01:A0:79:75:52:46:EA:80:77:93:4E:
57:13:D2:16:1B:FB:53:CF:84:4C:23:C6:08:2F:EB:D8:EC:A5:FA:13:
95:65:45:D7:CE:E2:1F:97:F4:5B:65:2D:0D:95:89:0F:26:15:53:88:
D9:B9:33:92:74:18:1A:C7:92:D6:AD:99:79:AA:7F:46
parm: NvSwitchRegDwords:NvSwitch regkey (charp)
parm: NvSwitchBlacklist:NvSwitchBlacklist=uuid[,uuid...] (charp)
parm: NVreg_ResmanDebugLevel:int
parm: NVreg_RmLogonRC:int
parm: NVreg_ModifyDeviceFiles:int
parm: NVreg_DeviceFileUID:int
parm: NVreg_DeviceFileGID:int
parm: NVreg_DeviceFileMode:int
parm: NVreg_InitializeSystemMemoryAllocations:int
parm: NVreg_UsePageAttributeTable:int
parm: NVreg_EnablePCIeGen3:int
parm: NVreg_EnableMSI:int
parm: NVreg_TCEBypassMode:int
parm: NVreg_EnableStreamMemOPs:int
parm: NVreg_RestrictProfilingToAdminUsers:int
parm: NVreg_PreserveVideoMemoryAllocations:int
parm: NVreg_EnableS0ixPowerManagement:int
parm: NVreg_S0ixPowerManagementVideoMemoryThreshold:int
parm: NVreg_DynamicPowerManagement:int
parm: NVreg_DynamicPowerManagementVideoMemoryThreshold:int
parm: NVreg_EnableGpuFirmware:int
parm: NVreg_EnableGpuFirmwareLogs:int
parm: NVreg_OpenRmEnableUnsupportedGpus:int
parm: NVreg_EnableUserNUMAManagement:int
parm: NVreg_MemoryPoolSize:int
parm: NVreg_KMallocHeapMaxSize:int
parm: NVreg_VMallocHeapMaxSize:int
parm: NVreg_IgnoreMMIOCheck:int
parm: NVreg_NvLinkDisable:int
parm: NVreg_EnablePCIERelaxedOrderingMode:int
parm: NVreg_RegisterPCIDriver:int
parm: NVreg_EnableResizableBar:int
parm: NVreg_EnableDbgBreakpoint:int
parm: NVreg_EnableNonblockingOpen:int
parm: NVreg_RegistryDwords:charp
parm: NVreg_RegistryDwordsPerDevice:charp
parm: NVreg_RmMsg:charp
parm: NVreg_GpuBlacklist:charp
parm: NVreg_TemporaryFilePath:charp
parm: NVreg_ExcludedGpus:charp
parm: NVreg_DmaRemapPeerMmio:int
parm: NVreg_RmNvlinkBandwidth:charp
parm: NVreg_ImexChannelCount:int
parm: rm_firmware_active:charp
Anyone out there that can help me out here?
