Can't get output tensor from model
Deepstream 6.1
Hello! I have a question about SGIE. I’m trying to get a response from the model, but the list that should contain the information is empty. The pipeline is PGIE - Tracker - SGIE. In the model configuration, the SGIE classifier-async-mode is set to 1, and the output-tensor-meta is set to 1. If i set classifier-async-mode to 0, everything works, and i can get a response. I can also get the track-id from the tracker, which means that the tracker is working correctly. Additionally, when i change the secondary-reinfer-interval, the GPU load changes, indicating that the model is working in asynchronous mode. SGIE model output is vector. How can i get output from model?
Thanks for help!
• DeepStream Version
• TensorRT Version
• Hardware Platform - GPU
• DeepStream Version 6.1
• TensorRT Version - 8.2.5.1
• NVIDIA GPU Driver Version - 510.108.03
• Issue Type - questions
please find async_mode 's explanation in nvinfer.in async model, the buffer wil be pushed downstream without waiting for inference results, but the consecutive frames’s classification should be same. after inference ends, there will be classification meta in object’s meta.
