Currently i try to bring up two cameras with Ser/Deser. The connection is two max9295(each with a ar0233 in remote end) connect to one max9296, and then route to SOC with one CSI. My device tree is similar with below reference, the difference is our platform don’t have i2c switch, and we reconfig max9295’s slave address through max9296 during sensor probe.
The problem is when only one max9296 link configured, the picture could be captureed. But once both links configured, the sensor could preview before would dump a lot of errors as below, and the other still same green picture as link unconfigured before. Both max9295’s I2C should work fine, as read back is ok after write. Could you help to check what reason raise below errors? How to do further debugging? Thanks!
device tree reference:
…/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-modules/tegra186-camera-imx390-a00.dtsi
log:
[ 73.669707] ar0233 8-001b: ar0233_power_on: power on
[ 73.671882] ar0233 8-001b: ar0233_power_off: power off
[ 73.673867] ar0233 8-001c: ar0233_power_on: power on
[ 73.674050] ar0233 8-001c: ar0233_power_off: power off
[ 73.899842] ar0233 8-001b: ar0233_power_on: power on
[ 73.900224] ar0233 8-001b: ar0233_power_off: power off
[ 73.904860] ar0233 8-001c: ar0233_power_on: power on
[ 73.905036] ar0233 8-001c: ar0233_power_off: power off
[ 73.924521] ar0233 8-001b: ar0233_power_on: power on
[ 73.986038] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 512
[ 73.987734] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 74.014690] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.014900] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 256
[ 74.019497] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 74.021792] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 74.021992] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.047905] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 74.054324] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.054543] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 74.081193] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 74.087600] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.114541] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.120956] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.147861] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.154278] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.181239] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.187552] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.187755] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.214565] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 74.220949] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 74.221155] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.247912] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 74.254308] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.281166] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.287583] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.314510] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.320976] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.347887] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.354120] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.381197] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.387625] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.414492] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.420910] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.447830] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.454306] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.454532] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 74.481156] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 74.487511] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.514511] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.520894] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.521108] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.547800] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 74.554231] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.581123] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.587566] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.614617] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.620954] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.647862] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.654202] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.681214] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.687600] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.714591] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.720914] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.747777] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.754365] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.781150] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.787510] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.814530] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.820856] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.821040] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.847823] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 74.854221] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.854416] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 74.881177] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 74.887598] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.914552] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.920935] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.947791] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.954184] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 74.981198] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 74.987571] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.014481] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.020918] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.047796] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.054140] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.081126] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.087572] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.114467] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.120908] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.121113] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.147785] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 75.154125] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.181074] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.187527] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.214445] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.220815] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.247711] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 166, err_data 160
[ 75.254193] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.254385] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 75.281049] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 75.287508] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.314534] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.320894] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.347772] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.354203] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.381021] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.387444] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.414412] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.420853] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 75.421057] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.447830] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 75.454183] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.481050] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.487423] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.514461] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.520857] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.547761] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.554084] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.581023] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 166, err_data 160
[ 75.587502] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.614419] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.620851] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.647698] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.654211] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.654413] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 75.681083] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 75.687409] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.714480] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.720886] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.721079] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.747791] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 75.754149] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.781002] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.787388] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.814400] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.820798] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.847725] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.854027] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.881049] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.887391] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.914636] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.920786] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.947734] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.954096] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 75.981135] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 75.987410] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 166, err_data 160
[ 76.014426] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.020707] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.047670] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.054107] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.054329] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 76.081118] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 76.087402] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.114379] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.120740] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.147724] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.154049] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.180957] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 76.187487] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.187677] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.214469] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 76.220827] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.247782] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.254087] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.281034] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.287290] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 166, err_data 160
[ 76.314329] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.320660] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.347729] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.353986] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.380987] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.387392] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.414353] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.420668] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.447656] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.454099] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.454295] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 76.481036] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 76.487404] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.487599] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.514421] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 76.520704] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.547726] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.553912] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 166, err_data 160
[ 76.581016] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.587357] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.614335] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.620725] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.620927] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.647764] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 76.654120] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.654311] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.680958] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 76.687374] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.714292] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.720706] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.720896] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.747639] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 76.753942] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.780953] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 76.787286] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.814297] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.820764] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.820971] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.847660] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 76.854079] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.854280] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 76.880976] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 76.887386] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.887584] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.914299] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 76.920779] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.920984] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.947750] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 76.954059] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.954278] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 76.980920] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 76.987334] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 76.987549] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.014371] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.020686] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.047707] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.053997] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.054201] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.080976] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.087253] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.114395] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.120654] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.120881] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.147657] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.154083] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.154284] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.180890] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.187252] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.214192] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 77.220607] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.220887] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.247598] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 77.254028] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.254234] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 77.281015] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.287350] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.287550] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.314260] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.320701] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.320904] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.347631] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.353886] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.380938] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.387251] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.387437] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.414148] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 77.420651] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.447646] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.453972] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.454158] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.480879] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.487240] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.514265] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.520577] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.520773] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.547560] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 77.553974] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.554208] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.580977] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.587307] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.614220] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.620665] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.620944] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.647638] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.653981] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.654192] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 77.680821] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 77.687258] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.687480] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.714341] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.720691] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.720917] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.747527] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.753849] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.780901] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.787272] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.787490] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.814300] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.820558] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.820762] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.847546] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.853883] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.854079] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.880878] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.887290] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.914195] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.920614] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.920894] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.947591] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.953885] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 77.954088] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 77.980864] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 77.987180] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.014189] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.020621] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.020844] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.047710] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 78.053927] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.054129] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 78.080846] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 78.087211] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.087408] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.114262] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 78.120511] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.147572] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.153876] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.154098] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.180784] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 78.187233] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.187455] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.214202] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 78.220593] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.247533] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.253685] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 166, err_data 160
[ 78.253909] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.280771] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.287141] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.287335] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.314280] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 78.320588] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.320793] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.347510] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 78.353899] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.354099] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.380815] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 78.387197] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.414174] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.420516] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.447559] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.453849] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 166, err_data 160
[ 78.454045] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 78.480870] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 78.487231] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.487455] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.514164] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 78.520572] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.520776] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.547553] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 78.553761] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.580836] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.587137] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.587336] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.614194] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 78.620569] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.647501] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.653908] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.654097] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.680750] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 78.687076] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.714259] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.720510] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 230, err_data 4194400
[ 78.720716] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 224, err_data 4194400
[ 78.747474] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
