Hi!
I recently updated one server with a Titan V GPU, running CentOS 7.5.1804, to CUDA 10. Following the requirements, I updated the nvidia driver to version 410.93. (I previously had CUDA 9.2 and driver 396.37).
However, now when I try to get the power consumption of the GPU I get N/A. It is worth noting that with the previous CUDA and driver versions I had no issue getting the power usage of the same GPU.
Example:
$ nvidia-smi
Mon Jan 28 17:31:27 2019
| NVIDIA-SMI 410.93 Driver Version: 410.93 CUDA Version: 10.0 |
| 0 TITAN V Off | 00000000:01:00.0 Off | N/A |
| 40% 52C P8 N/A / N/A | 0MiB / 12036MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
For curiosity, I also tried with the driver version 415.27, and ended up with the same results:
$ nvidia-smi
Mon Jan 28 17:43:21 2019
| NVIDIA-SMI 415.27 Driver Version: 415.27 CUDA Version: 10.0 |
Is this a known issue of these driver versions + the GPU? Am I doing something wrong?
nvidia-bug-report.log.gz (1.03 MB)
