I’ve been trying to get my custom baseboard to work with my IMX477 camera (2-lanes setup)… But with no success.
the output of media-ctl says:
Media controller API version 0.1.0
Media device information
driver vi
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 0.0.0
Device topology
- entity 1: nvcsi--1 (2 pads, 0 link)
type V4L2 subdev subtype Unknown flags 0
pad0: Sink
pad1: Source
Which is odd… I’ve read the Sensor Software Driver Programming Guide, and setup the DTS accordingly…
What would be the problem, here ?
Edit: I’m adding the extracted dts from the system…
extracted.dts (263.2 KB)
What’s the dmesg | grep -i imx477 show?
Which version?
L4T version is 32.4.3
Camera I2C is behind a TCA9548A mux, but I’ve checked I2C reaches the camera using an oscilloscope…
[ 5.663832] imx477 30-001a: probing v4l2 sensor at addr 0x1a
[ 5.669658] imx477 30-001a: avdd, iovdd and/or dvdd reglrs. not present, assume sensor powered independently
[ 5.679927] imx477 30-001a: tegracam sensor driver:imx477_v2.0.6
[ 5.686429] imx477 30-001a: imx477_power_on: power on
[ 5.728152] imx477 30-001a: imx477_read_reg: i2c read: 0xs0 = 0
[ 5.745482] imx477 30-001a: imx477_read_reg: i2c read: 0xs1 = 0
[ 5.767395] imx477 30-001a: imx477_read_reg: i2c read: 0xs200 = 7
[ 5.776148] imx477 30-001a: imx477_read_reg: i2c read: 0xs201 = 0
[ 5.782270] imx477 30-001a: imx477_power_off: power off
[ 5.788040] imx477 30-001a: ctrl Gain range update failed
[ 5.806633] imx477 30-001a: Error -34 updating mode specific control ranges
[ 5.813634] imx477 30-001a: Error -34 updating control ranges
[ 5.819405] imx477 30-001a: Failed to init ctrls imx477
[ 5.824688] imx477 30-001a: tegra camera subdev registration failed
[ 5.831187] imx477: probe of 30-001a failed with error -34
Maybe need to fix those error for driver probe.
Indeed.
There was additional unfixed errors in the driver.
The DTS needed some minor changes too, but I rushed it and can’t recall which ones, unfortunately.
Anyway, thanks !
The driver works, now btw…
driver vi
serial
bus info
hw revision 0x3
Device topology
entity 1: nvcsi–1 (2 pads, 2 links)
device node name /dev/v4l-subdev0
pad0: Sink
← “imx477 30-001a”:0 [ENABLED]
pad1: Source
→ “vi-output, imx477 30-001a”:0 [ENABLED]
entity 4: imx477 30-001a (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev1
pad0: Source
[fmt:SRGGB10_1X10/4032x3040 field:none colorspace:srgb]
→ “nvcsi–1”:0 [ENABLED]
entity 6: vi-output, imx477 30-001a (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
← “nvcsi–1”:1 [ENABLED]
