So i downloaded the sdk and generated a project using CMake
But when i run the sample code it just opens the video window for a few seconds before closing and it gives me this error on command prompt: “videoio(MSMF): can’t grab frame. Error: -2147483638
ERROR: Video error”
I get this error no matter which .exe i run
Which platform are you on? Are there multiple video input devices connected?
You can try forcing the Video Capture API to CAP_DSHOW instead of the problematic CAP_MSMF by adding it as second argument to the VideoCapture.open function.
For example in the ExpressionApp sample:
NvCV_Status App::setInputCamera(int index, const std::string& resStr) {
if (!_vidIn.open(index, cv::VideoCaptureAPIs::CAP_DSHOW))
return NvFromAppErr(APP_ERR_OPEN);
However it also might by a driver or hardware compatibility issue with your video input device.
