Can’t I change i2s setting using dtsi with jetson xavier nx kernel source?
b/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi
In Jetson nano kernel source, b/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi
I was able to configure pinmux in the file like below
Is it possible to use dtsi created through pinmux configuration table in Jetson xavier?
- dap4_din_pj5 {
- nvidia,pins = “dap4_din_pj5”;
- nvidia,function = “i2s4b”;
- nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
- nvidia,tristate = <TEGRA_PIN_DISABLE>;
- nvidia,enable-input = <TEGRA_PIN_ENABLE>;
Thank you.
