Apparently the Mac version is not compatible and the installation wont even open.
Hi emongev7h0m7,
I couldn’t reproduce this issue on Mac 10.13.6.
A possible way for further investigation is to check what error message comes up if CodeWorks is started up in command line. Can you please try below steps:
- Double click CodeWorks image to mount it.
- Open a terminal and run following commands
- cd /Volumes//.app/Contents/MacOS
- ./Launcher
Can you please paste the error message on your terminal?
I am also having this problem with 1R7 and 10.13.6, here is the terminal message:
dyld: Library not loaded: /usr/local/opt/openssl/lib/libssl.1.0.0.dylib
Referenced from: /Volumes/CodeWorks-1R7-osx_b104/CodeWorks-1R7-osx_b104.app/Contents/MacOS/./Launcher
Reason: image not found
Abort trap: 6
Update: I seem to have fixed this by installing openssl
Yup same error as darin_smyth:
Abort trap: 6
Installed open ssl and that indeed made it work :)
Thanks darin_smyth!
