Can't install gobject-introspection for python binding usage on Jetson with Deepstream 6.3
**• Hardware Platform Jetson
**• DeepStream Version 6.3
**• JetPack Version 5.1.2 GA
**• TensorRT Version
**• Issue Type bugs
**• How to reproduce the issue ? sudo apt install gobject-introspection
Deepstream C++ test applications work fine but i can’t install python binding from GitHub - NVIDIA-AI-IOT/deepstream_python_apps at v1.1.8 (v1.1.8 is the good version to target deepstream 6.3 )
I try to install binaries or compile binding i have the same error. python need dependencies to gobject-introspection.
if i try to install it via sudo apt install gobject-introspection, i have an error :
The following packages have unmet dependencies:
gobject-introspection : Depends: libgirepository-1.0-1 (= 1.64.0-2) but 1.64.1-1~ubuntu20.04.1 is to be installed
gobject-introspection depends of libgirepository-1.0-1 from 1.64.0 to 1.64.2 and version 1.64.1-1 is installed , so what’s the problem ?
Did you also hit this error when installing the wheel? Releases · NVIDIA-AI-IOT/deepstream_python_apps · GitHub . Installing the wheel should be the most straightforward way and there should be no dependency issues.
If you are building the bindings, make sure to follow the steps ( deepstream_python_apps/bindings at v1.1.8 · NVIDIA-AI-IOT/deepstream_python_apps · GitHub).
Please provide the full steps&logs before the error happens if there is still such an issue.
when i say “I try to install binaries” i’am talking about install wheel. i show you pip install pyds-1.1.8-py3-none-linux_aarch64.whl output result bellow :
Processing ./pyds-1.1.8-py3-none-linux_aarch64.whl
Collecting PyGObject
Using cached pygobject-3.48.2.tar.gz (715 kB)
Installing build dependencies … done
Getting requirements to build wheel … done
Installing backend dependencies … done
Preparing wheel metadata … error
ERROR: Command errored out with exit status 1:
command: /opt/exavision/env/bin/python3.8 /tmp/tmp_c535g9e prepare_metadata_for_build_wheel /tmp/tmp4vivwtjw
cwd: /tmp/pip-install-a_74kqlc/PyGObject
Complete output (23 lines):
+ meson setup /tmp/pip-install-a_74kqlc/PyGObject /tmp/pip-install-a_74kqlc/PyGObject/.mesonpy-zal2wd55 -Dbuildtype=release -Db_ndebug=if-release -Db_vscrt=md -Dtests=false -Dwheel=true --wrap-mode=nofallback --native-file=/tmp/pip-install-a_74kqlc/PyGObject/.mesonpy-zal2wd55/meson-python-native-file.ini
The Meson build system
Version: 1.4.0
Source dir: /tmp/pip-install-a_74kqlc/PyGObject
Build dir: /tmp/pip-install-a_74kqlc/PyGObject/.mesonpy-zal2wd55
Build type: native build
Project name: pygobject
Project version: 3.48.2
C compiler for the host machine: cc (gcc 9.4.0 “cc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0”)
C linker for the host machine: cc ld.bfd 2.34
Host machine cpu family: aarch64
Host machine cpu: aarch64
Program python3 found: YES (/opt/exavision/env/bin/python3.8)
Found pkg-config: YES (/usr/bin/pkg-config) 0.29.1
Run-time dependency python found: YES 3.8
Found CMake: /usr/local/bin/cmake (3.29.2)
Run-time dependency gobject-introspection-1.0 found: NO (tried pkgconfig and cmake)
Not looking for a fallback subproject for the dependency gobject-introspection-1.0 because:
Use of fallback dependencies is disabled.
../meson.build:29:9: ERROR: Dependency 'gobject-introspection-1.0' is required but not found.
A full log can be found at /tmp/pip-install-a_74kqlc/PyGObject/.mesonpy-zal2wd55/meson-logs/meson-log.txt
ERROR: Command errored out with exit status 1: /opt/exavision/env/bin/python3.8 /tmp/tmp_c535g9e prepare_metadata_for_build_wheel /tmp/tmp4vivwtjw Check the logs for full command output.
Please install dependencies first
sudo apt install python3-gi python3-dev python3-gst-1.0 python-gi-dev git \
    python3 python3-pip python3.8-dev cmake g++ build-essential libglib2.0-dev \
    libglib2.0-dev-bin libgstreamer1.0-dev libtool m4 autoconf automake libgirepository1.0-dev libcairo2-dev
Yes i follow pre install step , output result of debian package install :
sudo apt install python3-gi python3-dev python3-gst-1.0 python-gi-dev git python3 python3-pip python3.8-dev cmake g++ build-essential libglib2.0-dev libglib2.0-dev-bin libgstreamer1.0-dev libtool m4 autoconf automake libcairo2-dev
Lecture des listes de paquets… Fait
Construction de l’arbre des dépendances
Lecture des informations d’état… Fait
autoconf est déjà la version la plus récente (2.69-11.1).
automake est déjà la version la plus récente (1:1.16.1-4ubuntu6).
build-essential est déjà la version la plus récente (12.8ubuntu1).
cmake est déjà la version la plus récente (3.16.3-1ubuntu1).
g++ est déjà la version la plus récente (4:9.3.0-1ubuntu2).
libcairo2-dev est déjà la version la plus récente (1.16.0-4ubuntu1).
libtool est déjà la version la plus récente (2.4.6-14).
m4 est déjà la version la plus récente (1.4.18-4).
python3 est déjà la version la plus récente (3.8.2-0ubuntu2).
python3-dev est déjà la version la plus récente (3.8.2-0ubuntu2).
python3-gi est déjà la version la plus récente (3.36.0-1).
python-gi-dev est déjà la version la plus récente (3.36.0-1).
python3-gst-1.0 est déjà la version la plus récente (1.16.2-2).
git est déjà la version la plus récente (1:2.25.1-1ubuntu3.11).
libglib2.0-dev est déjà la version la plus récente (2.64.6-1~ubuntu20.04.6).
libglib2.0-dev-bin est déjà la version la plus récente (2.64.6-1~ubuntu20.04.6).
libgstreamer1.0-dev est déjà la version la plus récente (1.16.3-0ubuntu1.1).
python3.8-dev est déjà la version la plus récente (3.8.10-0ubuntu1~20.04.9).
python3-pip est déjà la version la plus récente (20.0.2-5ubuntu1.10).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 188 non mis à jour.
Everything is up to date.
Why not install this library?
I tried to install the gobject-introspection-1.0 library but it does not exist in this exact version:
sudo apt install gobject-introspection-1.0
E: Impossible de trouver le paquet gobject-introspection-1.0
E: Impossible de trouver de paquet correspondant à l’expression rationnelle « gobject-introspection-1.0
I tried to install the library in a more generic way without specifying the version :
Certains paquets ne peuvent pas être installés. Ceci peut signifier que
vous avez demandé une configuration impossible, ou bien, si vous utilisez
la distribution « unstable », que certains paquets n’ont pas encore
été créés ou ne sont pas sortis d’« Incoming ».
L’information suivante devrait vous aider à résoudre la situation :
Les paquets suivants contiennent des dépendances non satisfaites :
gobject-introspection : Dépend: libgirepository-1.0-1 (= 1.64.0-2) mais 1.64.1-1~ubuntu20.04.1 devra être installé
E: Impossible de corriger les problèmes, des paquets défectueux sont en mode « garder en l’état ».
I have given the correct command
If you want to install gobject-introspection independently, it should be
sudo apt install libgirepository1.0-dev
Excuse me, I removed this package from my script because it was the one that caused the problem, by executing your command I came across this dependency problem again
 python3 python3-pip python3.8-dev cmake g++ build-essential libglib2.0-dev \  libglib2.0-dev-bin libgstreamer1.0-dev libtool m4 autoconf automake libgirepository1.0-dev libcairo2-dev
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
la distribution « unstable », que certains paquets n'ont pas encore
été créés ou ne sont pas sortis d'« Incoming ».
L'information suivante devrait vous aider à résoudre la situation :
 libgirepository1.0-dev : Dépend: libgirepository-1.0-1 (= 1.64.0-2) mais 1.64.1-1~ubuntu20.04.1 devra être installé
                          Dépend: gobject-introspection (= 1.64.0-2) mais ne sera pas installé
                          Dépend: gir1.2-glib-2.0 (= 1.64.0-2) mais 1.64.1-1~ubuntu20.04.1 devra être installé
                          Dépend: gir1.2-freedesktop (= 1.64.0-2) mais 1.64.1-1~ubuntu20.04.1 devra être installé
E: Impossible de corriger les problèmes, des paquets défectueux sont en mode « garder en l'état ».
if I try to install only libgirepository1.0-dev I have the same problem :
Run the following command firstly and then reinstall the dependencies.
sudo apt-get update
sudo apt-get install -f
Update is Ok.
sudo apt-get update
Atteint :1 https://download.docker.com/linux/ubuntu focal InRelease
Atteint :2 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Atteint :3 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
Atteint :4 https://nvidia.github.io/libnvidia-container/stable/deb/arm64  InRelease
Atteint :5 https://repo.download.nvidia.com/jetson/common r35.4 InRelease
Atteint :6 https://repo.download.nvidia.com/jetson/t234 r35.4 InRelease
Réception de :7 https://packages.microsoft.com/repos/code stable InRelease [3,590 B]
Réception de :8 https://packages.microsoft.com/repos/code stable/main arm64 Packages [17.4 kB]
Réception de :9 https://packages.microsoft.com/repos/code stable/main armhf Packages [17.2 kB]
38.2 ko réceptionnés en 1s (37.1 ko/s)
Install is ok too.
nvidia@tegra-ubuntu:~$ sudo apt-get install -f
sudo apt-get update and sudo apt-get install -f run without fail but the problem persist, i can’t install libgirepository1.0-dev or gobject-introspection
I don’t know what happened to your system. you can try to use sdkmanger to re-burn.
Or use docker
sudo docker pull nvcr.io/nvidia/deepstream:6.3-gc-triton-devel
xhost +
docker run --runtime nvidia -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.3 nvcr.io/nvidia/deepstream:6.3-gc-triton-devel
/opt/nvidia/deepstream/deepstream/user_deepstream_python_apps_install.sh --version 1.1.8
