I have just got the Jetson AGX that I am trying to setup. Unfortunately, something strange is happening with JetPack 4.1.1:
the terms and conditions checkboxes are not visible on the UI, so I can’t “accept” and process with the setup (see image attached). How to fix this issue?
Thank you in advance.
Hi mobicham,
Are you use below command to run JetPack-4.1.1?
$ ./JetPack-L4T-4.1.1-linux-x64_b57.run
Hi carolyuu,
Yes, strange that the checkboxes are not visible on the UI.
I gave up trying with JetPack and used the SDK Manager instead, was easier.
Hi mobicham,
Yes, SDK Manager is good to use.
You can also install the latest version JetPack on your Xavier board :)
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
