Can't install Jetpack 6.0 after release of 6.1
Hello @user117897 ,
I’d like to help you with the issue you’re facing. I’m using Ubuntu 20.04 as a host with SDK Manager version v2.1.0.11698. When I run the sdkmanager command to open the graphical interface, I see similar options to what you mentioned, only versions 6.1, 5.1.4, 5.1.3, 5.1.2, and 4.6.5. However, there’s an option at the bottom that states “Show all versions,” which reveals JetPack 6.0 (rev. 2). Could you check if you have this option as well?
Looking forward to your response!
Jose Morera
Embedded Software Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
