It worked as the manual at first…but when congiruing, it just went blank.
Since then I can’t flash the Nano. I’m using a Jetson nano developer guide P3450.
I’ve tried with different ways: flashed brand new microsd cards (V1, V3 - different storage sizes Scandisk brand or alike).
then I’ve tried sdkmanager…when flashing, just got errors when had 99% of progress
I’ve used sdkmanager CLI having this
when using putty, shows reboot-loop.
When trying to flash using -fla, it just stop in the initial part of the process
- I’m using a 5V-3A adapter, greenlight ok
- Doing flashing and sdkmanager in recovery mode (well detected)
Note I’m using WSL.
Physical inspection: everything looks ok.
Well…I just used the Jetson 3 minwhen configuring and then it’s been very frutrating as I’m not able to use it.
Please help!
Rod
