I’m following the document of “ACCELERATED GSTREAMER USER GUIDE” (pdf version), the installation step on the document is like this:
sudo add-apt-repository universe
sudo add-apt-repository multiverse
sudo apt-get update
sudo apt-get install gstreamer1.0-tools gstreamer1.0-alsa \
gstreamer1.0-plugins-base gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly \
gstreamer1.0-libav
sudo apt-get install libgstreamer1.0-dev \
libgstreamer-plugins-base1.0-dev \
libgstreamer-plugins-good1.0-dev \
libgstreamer-plugins-bad1.0-dev
but in my xavier, I have an error like this:
Preparing to unpack .../libopencv-dev_3.2.0+dfsg-4ubuntu0.1_arm64.deb ...
Unpacking libopencv-dev (3.2.0+dfsg-4ubuntu0.1) ...
dpkg: error processing archive /var/cache/apt/archives/libopencv-dev_3.2.0+dfsg-4ubuntu0.1_arm64.deb (--unpack):
trying to overwrite '/usr/bin/opencv_annotation', which is also in package opencv-dev 4.1.1-dirty
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
it seems that gstreamer1.0-plugins-bad
or libgstreamer-plugins-bad1.0-dev
is depending on OpenCV3.2, while my Xavier has v4.1.1.
Any solution to this problem? Thanks.
