Can't install NVIDIA driver to run CUDA
I have installed cuda8 on my GTX 950m Ubuntu 16.04 Laptop.
Running deviceQuery returned:
-> CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
I checked and there was no nvidia folder in the /dev/ directory.
whereis nvidia yields:
nvidia: /usr/lib/nvidia /usr/share/nvidia /usr/src/nvidia-378-378.13/nvidia
Is nvidia driver installed already? I tried installing ./NVIDIA-Linux-x86_64-375.39.run, after doing:
kill your current X server session by typing sudo service lightdm stop or sudo lightdm stop
Enter runlevel 3 by typing sudo init 3 and install your *.run file.
You might be required to reboot when the installation finishes. If not, run sudo service lightdm
start or sudo start lightdm to start your X server again.
But it caused a login loop, where I couldn’t login again.
I then typed the following comands:
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
sudo ubuntu-drivers autoinstall
sudo reboot
I was able to login now, but I am back on square one.
Is Nvidia Driver not installed? what do i do now?
I am in a similar situation. Did you get this resolved?
For Optimus-enabled GPUs (on laptops/ultrabooks,etc) installing nvidia-prime will fix the issue of no display after reboot of installing driver. You might need to remove the driver before attempting to re-install it with prime:
See for example: http://askubuntu.com/questions/858030/nvidia-prime-in-nvidia-x-server-settings-in-16-04-1/858036
My installation already has Nvidia prime. I tried running running that instruction and it shows that the requirements are already satisfied
@Rob, No I haven’t been able to resolve it yet.
My guess is that the CUDA library in the system is an older one.
Try a simple:
sudo apt-get install libcuda1-378
(replace the last 3 digits with whatever driver version you currently have installed)
