I can’t install scipy1.4.1, I install scipy1.4.1 from the source.
cd scpiy1.4.1
python3 setup.py install --user
The errors like below. Help me, pls.
building extension "scipy.ndimage._nd_image" sources
building extension "scipy.ndimage._ni_label" sources
building extension "scipy.ndimage._ctest" sources
building extension "scipy.ndimage._ctest_oldapi" sources
building extension "scipy.ndimage._cytest" sources
building extension "scipy._lib._ccallback_c" sources
building extension "scipy._lib._test_ccallback" sources
building extension "scipy._lib._fpumode" sources
building extension "scipy._lib.messagestream" sources
creating build/src.linux-aarch64-3.6/scipy/_lib
C compiler: aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
compile options: '-I/usr/include/python3.6m -c'
aarch64-linux-gnu-gcc: _configtest.c
aarch64-linux-gnu-gcc -pthread _configtest.o -o _configtest
success!
removing: _configtest.c _configtest.o _configtest.o.d _configtest
building extension "scipy._lib._uarray._uarray" sources
building data_files sources
build_src: building npy-pkg config files
creating scipy.egg-info
writing scipy.egg-info/PKG-INFO
writing dependency_links to scipy.egg-info/dependency_links.txt
writing top-level names to scipy.egg-info/top_level.txt
writing manifest file 'scipy.egg-info/SOURCES.txt'
reading manifest file 'scipy.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
no previously-included directories found matching 'benchmarks/env'
no previously-included directories found matching 'benchmarks/results'
no previously-included directories found matching 'benchmarks/html'
no previously-included directories found matching 'benchmarks/scipy'
no previously-included directories found matching 'scipy/special/tests/data/boost'
no previously-included directories found matching 'scipy/special/tests/data/gsl'
no previously-included directories found matching 'scipy/special/tests/data/local'
no previously-included directories found matching 'doc/build'
no previously-included directories found matching 'doc/source/generated'
warning: no previously-included files matching '*~' found anywhere in distribution
warning: no previously-included files matching '*.bak' found anywhere in distribution
warning: no previously-included files matching '*.swp' found anywhere in distribution
warning: no previously-included files matching '*.pyo' found anywhere in distribution
warning: no previously-included files found matching 'LICENSES_bundled.txt'
installing library code to build/bdist.linux-aarch64/egg
running build_clib
customize UnixCCompiler
customize UnixCCompiler using build_clib
building 'mach' library
error: library mach has Fortran sources but no Fortran compiler found
